steam line insulation ideas?
Re: steam line insulation ideas?
I have found that ordinary string is adequate for saturated lines, but even butcher.s string chars away on superheater lines. A couple of coats of barbecue black heat resistant paint insulate just enough to prevent the worst of "Instant ouch" burns. Regards David Powell
fiber glass woven tube cloth sleeves that can be slide over the steam lines before final assemble (Similar to a Chinese's finger puzzle) used to be available through power model check McMaster Carr
