Heat Source for Soldering Barrel Liners
Re: Heat Source for Soldering Barrel Liners
Got the Liner in at last . My Setup and Homemade Pipe Burner. Even heat and Rotation of the Barrel getting it up to Temp did wonders.
- Attachments
- IMG_20230429_103715_1.jpg (157.11 KiB) Viewed 5319 times
- IMG_20230420_092922.jpg (132.35 KiB) Viewed 5319 times
Excellent!! Heat issue solved! Bravo...
Pete
Pete
Just tryin'
10KPete is so right about Stay Brite flux and solder. Their flux is the greatest. I’ve been using Stay Brite since the mid 1970s, originally for model airplane work. Still using it today for all sorts of soldering. If installing a barrel liner, I would use Acraglas, though.
