Brass challenge
Russ Hanscom
Brass challenge
Post by Russ Hanscom »
Friend had a memento he wanted, cheap cast india brass, but sentimental. Someone else had previously tried with a regular torch and the result was still two pieces with ugly globs at the ends.
I spaced the bits out appropriately on a fire brick and clamped them down and rolled 1/8" brass brazing rod to 1/16" thick to match the sections, then cut bits to length and fitted into the gaps. I have a micro torch which let me heat areas without puddling the whole thing.
Turned out tolerably well, just need a bit of weathering and the repair will be hard to find.
Patio
Re: Brass challenge
Post by Patio »
Nice job Russ!
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Re: Brass challenge
Yep! Well done.
One thing. I suspect that it won't weather as one might hope. That's because the rod used is likely truly bronze (made of tin and copper), while the casting was likely made from brass, which contains a large percentage of zinc. Still, how nice it must be for the owner to have it back in one piece, and totally functional.
Re: Brass challenge
Post by Bill Shields »
patience of a saint..
spro
Re: Brass challenge
Post by spro »
Right neat.
N.R. Davis
Re: Brass challenge
Post by N.R. Davis »
Played with Brazing a Black Powder Cast Brass Trigger Guard. Took about 5 hours to get an idea of what works. Normally you heat the base metal then add the rod. Kept Globbing out on me..... Got the Base Metal real close to melting and then moved the flame to the Brass Rod, melting it and touching it to the Base Metal. Flowed and blended together great. May never need to do a job like that again.... Then again I talked with a guy about a Pitted Brass Pronged Butt Plate.
Re: Brass challenge
Putting solder on before you heat makes it easier
Great job :mrgreen:
