Help with pipe connection & terminology
seal killer
Post by seal killer »
All--
Another dummy question, this time concerning pipe connections. I need to connect a male 7/16"-24 to a male 1/2"-18. How do I do that? What is (are) the proper name(s) of the component(s)? (I got lost in the weeds.)
Picture of what I want to connect . . .
7-16-24 to 1-2-18.jpg (186.52 KiB) Viewed 2035 times
Thanks!
--Bill
You are what you write.
mklotz
Re: Help with pipe connection & terminology
Post by mklotz »
Type "pipe fittings chart" into Google images and you'll find lots of help, like this...
https://www.linquip.com/blog/types-of-pipe-fittings/
Regards, Marv
Home Shop Freeware
warmstrong1955
Post by warmstrong1955 »
The needle valve is threaded in 1/4" compression (ferrule) sleeve, which is 7/16-24, with a 20 deg seat.
The fitting next to it is 1/4" NPT, which is 18TPI, and would measure about 1/2". (1/4" pipe measures .54" OD)
I know of no single adapter to connect the the two together.
They do make needle valves, in 1/4"NPT x 1/4" compression tube. Might be the way to go?
Other Bill
warmstrong1955
Post by Bill Shields »
This is why God made solder
Rich_Carlstedt
Post by Rich_Carlstedt »
It's called a " Reducer Pipe Coupling "
normally they have a 1/8 or 1/4" reduced sized, so a 1/2 to 3/8 would be common
Your 7/16" thread is weird , so you may have to get a 1/2 to 3/8 and open up the small end
Rich
The vendors are screwy.. this is listed as a elbow , but it is not
https://www.lowes.com/pd/ReliaBilt-45-D ... 5013684399
seal killer
All--
Thank you for the help! That will get me going.
Bill S, solder is how I've always done it in the past. All my soldering stuff is in a box I have yet to unpack. Looks like that box might be next.
--Bill
Can you tao a thread?
What is the bore of each?
Charles T. McCullough
Post by Charles T. McCullough »
If that is a 1/4-inch compression fitting on the valve, I'd see about soldering a 1/4-inch tube into the male-to-male coupler and use the compression fitting to couple the two together. If the hole in the M-to-M coupler is too small, drill it out half way. If it is too big, insert a wood dowel in the other end to the middle and tin 1/2-inch of the copper tube. Then stand the coupler on the dowel, flux the hole and set the tube, centered, in the hole. Apply heat to the end of the coupler until solder flows easily into the gap between the tube and coupler. But I guess I am a cheapskate with no knowledge of the pressures or tension between the pieces that might be involved.
Last edited by Charles T. McCullough on Sun Feb 26, 2023 5:41 pm, edited 1 time in total.
https://www.mscdirect.com/product/details/01601665
Valve with pipe thread on one end, tube on the other
Bill Shields wrote: Sun Feb 26, 2023 7:10 am https://www.mscdirect.com/product/details/01601665
Not likely a good candidate considering it is for 3/8" tubing.
liveaboard
Post by liveaboard »
Disassemble the valve
Cut the thread down to a smooth tube.
Bore the other fitting to match.
Solder them together
Reassemble
