Silver soldering torches
Mike Walsh
Re: Silver soldering torches
Post by Mike Walsh »
I was given a few J40 torches from Barry Moore a few years before he passed away, along with some regulators. Recently I picked up a small set of pony tanks... So I'm looking forward to getting it all set up. Hopefully they'll accept the pony tanks on swap.
Bummed the J40's don't come with flashback arrestors. Not sure how comfortable I feel about that.
Post by Bill Shields »
So purchase add on arrestors...or am I missing something?
Mike Walsh
Bill Shields wrote: Sun Feb 05, 2023 11:21 pm So purchase add on arrestors...or am I missing something?
I am.. LOL. I've never sourced, purchased, or owned a torch so this is new territory for me. Not to say I can't handle a torch, but I've always used others' torches.
Odyknuck
Post by Odyknuck »
Thoughts on this setup for doing Loco tubing work up to 5/16 OD:
https://www.amazon.com/dp/B09J1Y21H6/re ... s9dHJ1ZQ==
I have something similar and use it for really small stuff.
Mine does not come from china, but concept the the same.
Had it on shelf for 20 years, inherited and considered a toy until I actually used it...now is my go to for small stuff .
RThomp
Post by RThomp »
It's O/A though vs the propane of the others. The more I think about it, there's a pretty clear advantage with cost and just ease of re fill etc with using a 20lb propane bottle.
The amount of acetylene that torch used is miniscule.
One small pony bottle would last 5 years :mrgreen:
WRT flash back arresters:
50 years ago I was advised to put the arrester on the torch and not the regulator, to help keep the possible flash from happening in the hose.
Makes the handles a bit klunky to work with, but the suggestion made sense. No choice on the tiny torches, hence I have 2 arresters for each hose.
I also avoid such from other than reputable USA or British manufacturers.(victor or smiths)
Like my motorcycle helmets...worn for decades, never (thankfully) had to use.
SteveR
Post by SteveR »
I used to do some glass blowing for building vacuum lines and we used these. They work well for silver soldering small stuff. I use natural gas and oxygen, but you can use Natural Gas, Propane or Butane: . 25 - 5 psi: Oxygen : 2 - 10 psi. Different sized tips and glassblowing (neodymium) glasses so I can see what I'm doing (takes out the yellow sodium light). :D
wale torch.jpg (11.49 KiB) Viewed 1592 times
Wale Apparatus: https://www.waleapparatus.com/
SteveR
Not enough measuring tools...
1" FEF in progress
1" & 3/4" LE Projects
I'm thankful that metal is recyclable....
paralleler
Post by paralleler »
Youtube hobby machinist Blondihacks (Quinn Dunki) is starting with the boiler of a 3-1/2" gauge 0-4-0 switcher. I am really enjoying it and will be happy when it passes its boiler test. She talks about the silver soldering equipment she's using in Part 1 starting at 14:55.
See: https://www.youtube.com/watch?v=yiAWsopdr0A&t=895s
The medium is 1-1/2", large is 2"
NOTE: Two setups in photo - Sievert Torch is actually propane.
looks a lot like my setup -> only i have a longer 'extension pipe' on mine since the boilers are bigger....
