Does anyone have any info on which axis feed will fit on a Select 6 x 26 Taiwan mill? I've had it for over a year and it's time to upgrade it.
Any info would be greatly appreciated.
Davisa
X-axis feed for Select 6x26 mill.
Re: X-axis feed for Select 6x26 mill.
Take a look at my thread Rockwell milling machine rebuild @ top of page.
Look at page 3 & 4 . Should give you some ideas.
Every power feed will require a certain amount of adaptation.
Reason: Added link to the other thread
As much as you may not to want to go this direction, but Servo feeds provide the most comprehensive data for installation dimensions.
They are also the most $, but have been around for decades and provide parts and service you may not get from others.
