01 oil hardened steel machinability
Odyknuck
Post by Odyknuck »
How well does the material machine as it comes from factory? Here is the link to McMaster car:
https://www.mcmaster.com/catalog/129/4217/9516K624
Re: 01 oil hardened steel machinability
Post by Bill Shields »
Quite nice...just keep it cool
An alternative that I also use is ground to size hot rolled.
It used to be quite a bit less expensive.
Odyknuck
Post by Odyknuck »
Thats good to know, thanks. My Mikado came with tool steel reverse links, and I am trying to pair them up with similar steel to make the die blocks. I also seen recently a guy who used Bronze for the die blocks.
Suggest bronze for that application unless the links are hardened.
When you make them....make extras
They take a beating
Odyknuck
Post by Odyknuck »
They came with the project so there is some uncertainty of actual material. The file test shows them harder than mild steel however by how much I cannot say. They are defiantly not hard like HSS or equivalent as the file does remove material however slowly.
I would do bronze...but once you are setup.....
I recommend making the die blocks from tool steel, hardened post-machining.
Their relatively small contact area in the reverse links will wear non-ferrous metals rather quickly, as Bill implied.
The prolonged discussion in regards to tool steel.
Are any of you folks familiar with (O6)Graph-Mo? It's one of the nicest to machine tool steels to be developed and offers excellent wear qualities. Available as precision ground flat bar in an endless selection of widths and thicknesses, in either 18" or 36" lengths. Based on my experiences of many years ago, anyway. The free machining quality is highly unlikely to have changed, but the sizes may have.
On that subject, proper heat treating is often a stumbling block, and can result in altered dimensions. Some materials are more stable than others, and often can be the solution to negative experiences. Graph-Air (A10) is an excellent substitute when distortion is an issue. It, too, has excellent machining and wear qualities.
Just sayin'
Harold:
Thank you for that educational input. I was familiar with Graph-Air, but not Graph-Mo.
More to learn.
RSG
Post by RSG »
I work with O1 all the time and fine it a pleasure to machine.
