Amazing machine work
Re: Amazing machine work
Yes . They DO have products that intentionally cause a positive outbound airflow
Bill Shields wrote: ↑Wed Nov 16, 2022 2:37 pm unless it's intended job is to lubricate the outer skin of the aircraft
In that respect, a radial engine has no peers.
- liveaboard
Lucas electrical used to be known as "the prince of darkness".
That mainly referred to the intensity of vehicle driving lights...
But not everything they made was (is) bad. My 22 year old car has Lucas diesel injection pump and it's still working perfectly.
Ok, not really; it's supposed to pull fuel from the tank through the filter without an auxiliary (lift) pump. That is to say, it's supposed to really suck but like the vacuum cleaners, it sort of doesn't.
I added an electric fuel pump, now it works just great.
You have obviously never ridden an older British motor cycle..BigDumbDinosaur wrote: ↑Thu Nov 17, 2022 12:08 pmBill Shields wrote: ↑Wed Nov 16, 2022 2:37 pm unless it's intended job is to lubricate the outer skin of the aircraft
Now that I just ran a piece of stainless safety wire all the way through my finger I may re-think this!GlennW wrote: ↑Wed Nov 16, 2022 1:29 pmOh, you mean like this arrangement to secure a threaded plug?BigDumbDinosaur wrote: ↑Wed Nov 09, 2022 2:54 pmThe British were notorious for using 10 parts to do the work of five,
A simple piece of safety wire to secure the plug would have worked just fine.
GlennW wrote: ↑Thu Nov 17, 2022 4:19 pmNow that I just ran a piece of stainless safety wire all the way through my finger I may re-think this!GlennW wrote: ↑Wed Nov 16, 2022 1:29 pmOh, you mean like this arrangement to secure a threaded plug?BigDumbDinosaur wrote: ↑Wed Nov 09, 2022 2:54 pmThe British were notorious for using 10 parts to do the work of five,
Want me to kiss it for you and make it worse?
I've not completely penetrated my finger that way with safety wire, but have poked my share of holes over the years. It always hurts like hell when I do it.
Bill Shields wrote: ↑Thu Nov 17, 2022 1:10 pmYou have obviously never ridden an older British motor cycle..BigDumbDinosaur wrote: ↑Thu Nov 17, 2022 12:08 pmBill Shields wrote: ↑Wed Nov 16, 2022 2:37 pm unless it's intended job is to lubricate the outer skin of the aircraft
I know that they can go fast, but didn’t know British motorcycles can fly.
OH YES....they can fly....for short periods of time.
#12 headed out the door.
Very nice, Glenn. You sure do pretty work.
Thank you, Sir!
You have been a big influence in the parts making part of what I do.
Thank you for that!
Thank you for that!
