HF 44142 - Need new crossfeed nut
magicman
Crossfeed nut
Post by magicman »
I also had a problem with the cross feed not. Based on the amount i used it i would have to call it a manufactures defect. I currently have .009 play in the cross feed not.
Trying to figure out how i could split the nut like another member suggested.
Jose Rivera
Backlash eliminator
Post by Jose Rivera »
I am posting two close-up pictures of what my lathe has.
The cross-slide has almost zero backlash, it will spoil you, I promise.
The pointed set-screw splits open the gap eliminating play. It will wear out, but it can be tighten some more until it will have to be replaced.
magicman
Post by magicman »
How do i see pictures? Sorry new here. I think i understand the idea of splitting the nut now though. Once i am done moving i will try it
magicman
turning new nuts
Post by magicman »
if anyone figures out how to turn new nuts let me know. "PLEASE" :)
magicman
same nut
Post by magicman »
I have same setup as lodcom. (Don't know how but i now have pictures). thinking if i cut the nut then turn both backwards i could in effect split the nut and remove my play.
Jose Rivera
Seeing pictures
If you have join in the board and have been accepted, you must be login.
Look at the top where there are option like ?FAQ, Search, Memberlist, etc.
If at the lower row you see Login, the you have not login.
It was to say "Log out and the [your name or nickname]
Otherwise you cannot post or see any pictures.
Re: Seeing pictures
Jose Rivera wrote:If you have join in the board and have been accepted, you must be login.
If you can't see pictures after following Jose's advice, your firewall may be blocking them.
Ryan Neuhauser
Cross feed nut
Post by Ryan Neuhauser »
I have a smithy midas 1720 which I believe is pretty close to identical to the HF44142. The Smity forum has the manual with parts break down for the cross slide. You may be able to get it from Smithy.
Ryan
lodcomm
Post by lodcomm »
Hi,
thanks for the input - how/where do I access that forum for the
parts manual?
thanks
-todd
Ryan Neuhauser
HF 44142 cross feed nut
The group I was referring to is smithy-machines and it is under groups on yahoo. The manual for thw Midas 1720 with parts break down is linked on that forum.
I hope it works.
RAN
snowrx
Re: HF 44142 - Need new crossfeed nut
Post by snowrx »
Kind of a hybrid, it's 20mm OD, but the pitch is standard 8 threads per inch (8tpi) I would assume it's a trapezoidal thread form since its on a mostly metric machine. Carriage lead is more of the same 20mm but with 6tpi. Toolots.com shows a similar (out of stock) nut for their Bolton BT800 machine @ $43, but no idea if it will work on the 44142.
I spent the day looking for a nut for this family of machines, but am thinking I'll end up making one, maybe with some extra length to add a split for adjusting it
Torch
Post by Torch »
You might want to check out my experience in this thread:
http://chaski.org/homemachinist/viewtopic.php?t=111419
