I recently purchased a used Bolton 10x22 lathe and am trying to learn how to use it. Some of my early test cuts were producing a very rough finish and I noticed there is a lot of movement ~3mm towards or away from the operator in the cross slide. You can see the movement in this quick video https://photos.google.com/photo/AF1QipM ... Ty4JcOdOpP See post #4, below, for a functional link
So a few questions I'm hoping you more experienced machinists can help me with:
Is this normal or expected behavior?
If not, should I add some washers/spacers in the assembly near the hand wheel to stop this movement?
Do I need to lock the cross feed with the cross feed lever when I want to along the length of material (as opposed to the face)
Rough finish can come from many different causes...not the least of which is that if you are cutting cold rolled steel...it is very difficult to get a good finish.
As Bill says, backlash is normal. But I think it's safe to say that 3 mm (almost 1/8") is more than you should expect. Let's get that link to the video working and then go from there.
I suggest you dismantle the handle assembly to try to determine why there's so much slack. That juncture should NOT display any lateral movement. What you are experiencing is not related to backlash, which should be expected.
Bill Shields wrote: ↑Sat Apr 23, 2022 4:15 pm
Ah...ok...check that the handle nut is tight...
...Or that the wheel is fully in towards the cross slide, tightening the nut as Bill said should
bring the hand wheel in, it might be a jam nut set up or a set screw ( may be hidden under the dial )
depending on how it was designed.
Adjust the so the hand wheel doesn't bind.
Also it looks like the lathe is moving extensively on its table mount, or that table is that loose.
A solid mount is required for any kind of accuracy when machining.
Thanks Russ, I had the camera on a pretty flexible arm suctioned to the table so it was bouncing around alot while videoing (the lathe is bolted through a pretty hefty timber and into the cabinet legs below).
I made up a spacer for the handle you can see here: https://photos.app.goo.gl/7448WpuapcDHbFVw8 (it's the black piece with the green arrow pointing to it) and that has taken out almost all the play.
Now I can get back to learning how more about how to use this thing
Josh:
Nice solution with the spacer.
All the lathes I've worked with (12+) have a nut to adjust the slop away.
Interesting that your lathe apparently lacks that capability.
I took note that your cross slide is equipped with a ball thrust bearing. That's a nice feature, one that will permit you loading the screw so the only slack will be the backlash, which I highly recommend you do. It's simple to do. Just check the existing clearance with a feeler gauge, then add the amount to the spacer you made. It can be something as simple as shim stock, as it won't be doing anything once properly installed and loaded. There should be no clearance on that fitting, as it will permit the cross slide to wander unnecessarily. Alternately, make a new spacer of the proper thickness. I'd suggest one a half thou thicker than the existing space.
I'm assuming that the proper load will still permit the dial to be rotated for zeroing. If it won't, then my thoughts are likely not correct.
