Engineering Workshop Manual 1938 (104p) (GREAT SHOP INFO) ****NO LONGER AVAILABLE****
This is where bits of wisdom will be stored, a frequently asked question section with answers.
ken572
Post by ken572 »
(ALL) :D
EngineeringWorkshopManual/Pull-EngineeringWorkshopManual.pdf
Enjoy. 8)
Ken. :)
One must remember.
Ken.
EricM
Re: Engineering Workshop Manual 1938 (104p) (GREAT SHOP INFO)
Post by EricM »
That link didn't work. Try this one: https://ia601605.us.archive.org/30/item ... Manual.pdf
Steggy
Post by Steggy »
Talk about an out-pf-date reference. :D In the section on steel making, no mention is made of the electric furnace process, which is commonly used to produce the high grade alloys. That tells me this book is a revision of a much earlier work, as the electric furnace process was developed around 1910, if memory correctly serves me.
JET
Post by JET »
The link provided says: Item not available
The item is not available due to issues with the item's content.
