Legality of owning a personal foundry.
sparks at foundry
Harold,
You wrote: "... having a little trouble visualizing a situation where sparks are an issue."
How about this? OK, OK, I'm a smart alec … It's a very large commercial iron foundry, not a home foundry.
But it is a neat photo.
Re: Legality of owning a personal foundry.
Andy:
If that pic was of a home foundry we would have read about the fire department response to save the house!
Depends on the house....lotsa steel, brick and concrete won't burn....
- liveaboard
Houses in Portugal are all masonry with ceramic tile roofs.
They still burn when wildfires pass through.
A number of years ago, I bought an old Duncan ceramic furnace, that saw little use, to see if I could melt some of the non-ferrous metals I use, but sorry to say I have yet to get it wired up. I also wanted to use it on the burn out of ceramic slurry coated styrofoam.
It is much too easy to lite off the natural gas fired McEnglvan B30, but one of these years I will do it.
On the other end I have a Kerr electric furnace that I have used many times in my basement, very little in fumes, and pouring into a vacuum creates no sparks or fumes.
I suspect, at +10,000 watts, the Duncan will be more costly to run than the B30, or even my B700, using natural gas, at least for now.
Re: sparks at foundry
Yep! And I strongly suspect that what you're seeing is the inoculation of gray iron, converting it to ductile iron. That's highly unlikely to happen in a home shop, although I've made provisions to do just that. I have yet to muster the courage to give it a go.
Harold: "...what you're seeing is the inoculation of gray iron, converting it to ductile iron.:
YES! Give Harold a cigar!
You know your stuff ! (as usual.)
Nonferrous metals do not spark like that in a home foundry. That is definitely iron which I would not suggest attempting for the average casual home foundry enthusiast.
-Frank K.
I agree, although some have enjoyed success melting gray iron with a crucible furnace. It's not easy and not cheap to do, due to the high temperature involved. A cupola, arc or induction furnace make it easier.
I've followed this thread since the beginning and although I don't believe there is anything 'illegal' about operating a home foundry you do have the responsibility to make sure that you don't jeopardize yourself or others. If you're planning to make a portable unit that you'll operate outdoors stay far away from buildings, trees and other flammable things; if your furnace is an inside unit like mine, you may want to have it inspected by the local building code officials. I didn't do that and while inspecting another project my shop and all of the things in it became an issue once discovered because it was all done without permits and inspections. Like I told the building inspector, this is my hobby, it will all be removed when I sell the house and it was all added piecemeal as I acquired things a little at a time. The building inspector still made me file for after the fact permits and inspections for the natural gas piping, electrical wiring, power phase converters, disconnects,transformers etc.. Everything passed but the fire inspection was a different story, although my house and attached garage are masonry he had an issue with the masonry chimney's 8" square flue that I built for the wood burning stove and blacksmith forge, two appliances in a common flue. It took a lot of convincing and an intervention from the building inspector to get him to ease up. Why did I mention all this, because you have to be comfortable about what you are doing. I was ok doing everything without permits until I got caught, I still have never mentioned that I have all this stuff to my homeowners' insurance carrier...I don't know how they would feel about it and don't plan to find out. But in all cases be carefull and use common sense.
John
John
