Linuxcnc Z Tool Offsets
jmcghee
Post by jmcghee »
Hey guys-
I’m an experienced manual machinist but 100% CNC neophyte. There’s probably an obvious answer to this, but I can’t for the life of me sort it out. I'm trying to program my Z tool offsets (3 axis mill) running Linuxcnc with Axis interface and am pulling my hair out. I've got 15 or so tools in holders that should handle 99% of the work I'll do. I set all the Z heights in the tool table by doing the following:
-Load the tool & MDI a T(n) M6 G43
-Selected "touch off to fixture"
-Very carefully jog down to a machined flat piece of stock and take a whisper cut
-Hit tool touch off button and leave at 0
I repeated that process for all the tools on the same flat surface. As I understand it, the Z offsets for each tool are now set relative to one another, but not in space.
Then I made a fairly simple program that uses all the tools, with all of them taking a facing cut. My process was to edgefind my origin and hit the "touch off" (not "tool touch off") button in X and Y, load the tool, jog down & take a whisper cut in Z, and "touch off" in Z. I was expecting this process to work (seems pretty straightforward) but it definitely didn't. Using the above it'll cut air, somewhere around 2" above the stock top.
After some advice online I added g59.3 in the MDI before the command above and that didn't work either. Rather than cutting air, it'd start tool one a few inches below the part surface.
I reloaded all my tools 3 separate times just to make sure I didn't make a math error, or change something inadvertently, but no luck. feel like I'm missing something simple, but can't get it. Anyone see something obvious I left out?
GlennW
Re: Linuxcnc Z Tool Offsets
Post by GlennW »
You have to set the tool offsets in relation to a master which should be the same or slightly longer than the longest tool.
I use a piece of 3/8 drill rod in a tool holder as my master.
You zero the master and then record the difference in length of each individual tool relative to the master.
I have no idea what Linuxcnc is, so this is just general info.
FKreider
Post by FKreider »
Setting tool offsets can vary a bit by controller and machine however Centroid has an excellent video on the topic that may be helpful:
https://www.youtube.com/watch?v=iJcq_G8yRdc&t=1016s
You can also just search around on youtube using keywords- there are a ton of videos regarding tool offsets.
-Frank K.
