Welding Positioner
armscor 1
Welding Positioner
Post by armscor 1 »
Need to build up a shaft with weld.
Built this.
liveaboard
Re: Welding Positioner
Post by liveaboard »
We'll need to see that in action!
Russ Hanscom
Post by Russ Hanscom »
Ingenious, just don't that with a good chuck! I see you have the ground as close to the work as possible.
armscor 1
Post by armscor 1 »
Yep, no possibility of welding spindle bearings.
Made a 98 tooth gear to give me the speed reduction, goes down to just under 1 rpm.
The mill power feed was removed from my mill and I upgraded to an Align to give me higher rapid speed.
Going to make a slotted faceplate that will grip in the 3 jaw chuck to give me more versatility.
armscor 1
Post by armscor 1 »
Tested at 140 amps, no interruption to current, slip ring holds up, very happy.
fonzy
Post by fonzy »
Cool build. I just retired and recently posted a few videos on YouTube. This one has a turntable I built from a junk 7" grinder, and a foot operated one. Can be seen at:
https://www.youtube.com/watch?v=l4je9lowQj4
Please like, comment, and subscribe to my channel. Al
1969 Logan 1875 POWERMATIC 10" lathe, 1996 HF "MILL DRILL" Both with 20 year+ accumulative tooling!
Horz/Vert bandsaw AC/DC Stick Welder small wirefeed welder Oxy Acety Weld/cut ect.,
SEE MY INFORMATIVE VIDEOS AT http://www.youtube.com/user/alpho52
