O-Rings as piston rings
This Forum is dedicated to the Hobbyist I.C. (Internal Combustion) Engine Community.
Moderators: JackF, Harold_V
warmstrong1955
Re: O-Rings as piston rings
Post by warmstrong1955 »
No doubt, that if you go outside of the recommended fit, you will have leakage problems.
And to Harold’s point, I agree. If you try to get an o-ring to the same friction ‘feel’ as a cast iron ring, it will probably be out of tolerence, and too loose of a fit.
I’d like to know how it turns out too!
Other Bill
tornitore45
Post by tornitore45 »
Will report, I am still far away from that part of the construction.
Mauro Gaetano
in Austin TX
warmstrong1955
Oh sure.....keep us in suspense....
Other Bill
steamin10
Post by steamin10 »
Freind past used O-rings for a Tich. His solution was polished bores and two piece piston that could be adjusted on the rod for crush on the ring. This flies in the face of the way o rings are supposed to float, but it worked famously with little drag, once set up.
tornitore45
Interesting, but
What is a Tich? Steam? OR IC?
Mauro Gaetano
in Austin TX
"Tich" is a small 0-4-0 steam locomotive.
GlennW
Post by GlennW »
tornitore45 wrote: Tue Jul 17, 2018 5:39 am
Interesting, but
I'm guessing that your Hoglet is internal combustion?
tornitore45
The Hoglet is so called because is a V twin loosely inspired by the Harley Davidson engine.
Love the picture.
In Italy we call that a Porchetta once is stuffed and roasted.
Mauro Gaetano
in Austin TX
GlennW
Post by GlennW »
Italy, what a great place!
Some day I'll make it back there.
tornitore45 wrote: Tue Jul 17, 2018 3:54 pm The Hoglet is so called because is a V twin loosely inspired by the Harley Davidson engine.
Love the picture.
And delicious! :-)
warmstrong1955
Looks like potential carnitas to me, still on the hoof, speaking of delicious!
tornitore45
I used this calculator and adjust the numbers to have just over the minimum recommended ring radial compression, I settled for 12% http://www.applerubber.com/oring-gland-calculator/
It turns out the number match what Glenn W posted.
The bore is mirror finish and a funny thing I noticed.
The static friction is much higher than the the moving friction. That is a known fact but usually the difference is not too great.
I put a temporary crank on the V twin and it turn fairly smooth.
Thanks to all that helped.
Mauro Gaetano
in Austin TX
