(ALL)
NOTE: Much Info on Home Made Oxygen Methods
and Resources.
The book of lantern. (GREAT INFO)
Being a practical guide to the working of the optical
(or magic) lantern ; with full and precise directions
for making and colouring lantern pictures. 1888 (330p)
https://archive.org/details/cu31924031248051
EDIT: Add.
The Book of the Lantern.
Being a Practical Guide to the Working of the Optical,
(or Magic) lantern; 1889 (314p)
https://archive.org/details/booklanternbein01hepwgoog
Modern magic lanterns.
A guide to the management of the optical lantern
1900 (146p)
https://archive.org/details/cu31924031263183
Note: The above books complement this post below.
Oxy-Acet-Make-Welding-Cutting-With.(CAUTION)Update 10-11-13
http://www.chaski.org/homemachinist/vie ... 44&t=97010
(11-07-2014) EDIT UPDATE:
D.I.Y. Yeast-Generated CO2 System
http://www.cichlid-forum.com/articles/diy_co2.php
Enjoy.
Ken.
Home Made Oxygen Methods VERY INTERESTING.11-07-2014 Update
One must remember.
Ken.
Ken.
Re: Home Made Oxygen Methods VERY INTERESTING.11-07-2014 Upd
Hi Ken first if I did not reply with a thank u my apologies I have just come back to this issue and the info web address re the oxygen is not there. Plenty other stuff including Co2 from yeast etc. Could I trouble for a repeat,
Thanks Golfpin
Thanks Golfpin
Golfpin, Golfpin, Golfpin,golfpin wrote:Hi Ken first if I did not reply with a thank u my apologies I have just come back to this issue and the info web address re the oxygen is not there. Plenty other stuff including Co2 from yeast etc. Could I trouble for a repeat,
Thanks Golfpin
I guess we are not looking and reading.
Pages: 21, 22, 23,
In the book below.
1900 (146p)
Ken.
One must remember.
Ken.
Ken.
I find the chemical generation of oxygen interesting but in todays world mechanical generation may be more practical.
look at in home oxygen concentrators as a common source of oxygen .
here is a explanation of operation
https://en.wikipedia.org/wiki/Oxygen_concentrator
Hammer,hammermill wrote:I find the chemical generation of oxygen interesting but in todays world mechanical generation may be more practical.
I have looked at these and kinda doubt the concentrator would work
on a torch for cutting and or welding because of the lack of volume,
and pressure made, and it's also my thoughts that if you could make
one big enough to function in a cutting and or welding setup you
couldn't afford the cost for building it, and or operating it.
JMHO..
Ken.
One must remember.
Ken.
Ken.
http://www.chaski.org/homemachinist/vie ... 12&t=87931
here is one mans experience, I used them is the radiator shop back when they were brass (radiators that is) hihi
Hello Ken (AKA-Da, hammermill)hammermill wrote:http://www.chaski.org/homemachinist/vie ... 12&t=87931
Thank You, for sharing
Papa's Post from 2010.
With all my searching and research I've been doing
on this I missed Papa's Post, which turns out to be
the most informative and the best over all. Now all
I have to do is make a shopping list and look for
some good deals.
Ken.
One must remember.
Ken.
Ken.
the comerical units I am used to seeing have a storage tank that is clean and only used for oxygen. . estate sells will often have personal units
left over aftering a passing.
