Show us your milling machine!
AllThumbz
Post by AllThumbz »
Ok, here we go...to kick things off, let's see what type of lathe you use in your shop....
I have a Burke #4 in my tiny shop, with the master gearhead motor and vertical milling attachment:
Let's see what you have in your shop...
Best,
Nelson
a/k/a "Allthumbz"
tsph6500
Re: Show us your milling machine!
Post by tsph6500 »
I'm fixing up a Gorton 8-1/2D that was rescued from a scrapyard.
Best regards,
Jim Leggett
Montreal Live Steamers
www.montreallivesteamers.org
A Founding Member of the Tinkerbell Scale Society - Northern Division
I'm an A.R.S.E. (Association of Railroad Steam Engineers)
Toad Swamp & Punk Hollow Railroad - Head Tycoon
The Juvenile Traction Company - CEO & Apprentice Machinist 3rd Class
White Mountain Central RR - Engineer & Fireman
BobWarfield
Post by BobWarfield »
Industrial Hobbies Mill converted to CNC:
Cheers,
BW
Try G-Wizard Machinist's Calculator Free:
http://www.cnccookbook.com/CCGWizard.html
Russ Hanscom
Post by Russ Hanscom »
Here is my Gorton 1-22 with a senior Autocon Delta 40 CNC. Just for frustration(?), it uses the Kwick Switch tool holding system
Fender
Post by Fender »
Here is a picture of my Index model 55 vertical mill, still in the equipment dealers warehouse. I had to fix several defects, including the bent Y-axis handle, missing Z-axis handle, and a burned-out power feed motor, but the price was right.
Dan Watson
Chattanooga, TN
seal killer
Post by seal killer »
Russ--
Gee. That (Gorton 1-22) is a good looking mill! How much does that baby weigh?
--Bill
You are what you write.
Russ Hanscom
The Gorton is roughly 3500-4000#. Not an official weight but I did have to get a tandem axle trailer to bring it home. It is a very solid piece of machine. The seller threw in an old pallet jack so it was amazingly easy to move into the shop. A considerable change from the Fray 7B it replaced.
Davo J
Post by Davo J »
Hi,
Here is mine a HM52 equal to the Grizzly 3617, 3 axis DRO and 3 power feeds. I have pulled it down and cleaned all the sand and grit out of it. I have another DRO scale for the quill ,I just haven't re fitted it to this machine. After having problems with my first 2 machines I finally have one that's accurate.
Dave
seal killer wrote:Russ--
--Bill
The Gorton I-22 is the sleeper amongst drop spindle mills. They are to a BP what an EE Monarch lathe is to a Graziano.
MikeA
Post by MikeA »
OK, but no laughing! Comparing my milling machine to the heavy metal is a bit difficult - your vise probably weighs as much as my machine!
But...it fits into the area I have and handles anything I want it to do. A 'vintage' (euphemism for really old) early 1940s' Benchmaster MV1 I bought last year in rather poor condition and restored.
I considered what machine would work in my situation and it was either a small Chinese mill or the Benchmaster. As most of you probably know, these were made in California from the 40's through perhaps the 60's and aren't readily available but highly regarded for their capabilities. I'm pleased with mine.
Best,
Mike
After restoration
After restoration
As received
As received
Better is the enemy of good enough!
JackF
Post by JackF »
Here is my Comet 3KV mill with a 10X50" table. Bought it as a basket case for $600. Some before and after shots.
Jack.
As repaired, reassembled and painted
Dozer56
Post by Dozer56 »
All this heavy equipment in here, I'm embarrased to show my little machine.... Everyones looks great. This is they day I got mine set up about 6 weeks ago. been able to get through a few projects so far, next is a DRO that is arriving thurs.
