Will it manage?
Will it manage?
Hello all
I am intrested on buying a Cinese 3040 cnc for cutting 10mm aluminium hub ring for rims. Will it work?
Re: Will it manage?
Not sure I understand.
"Chinese"?
CNC lathe or mill?
Wheel hubs, or rims?
10mm thick or diameter?
So many questions...
"Chinese"?
CNC lathe or mill?
Re: Will it manage?
I believe he is asking about one of those CNC routers, such as https://www.alibaba.com/countrysearch/CN/cnc-3040.html
And further guess it's something along the lines of a 10mm thick wheel spacer.
Re: Will it manage?
Machining aluminum of that thickness can sometimes be quite an experience without flood coolant.
Re: Will it manage?
I bet everyone is looking up the CNC-3040 now.
Re: Will it manage?
Not quite everyone. I've learned that when people ask questions that raise more questions because they haven't invested enough time for their inquiry to make sense, I simply ignore them. That's unfortunate, as I'm more than happy (I'm actually eager) to help, assuming I'm able.
Brings to mind a person calling for an ambulance, but not disclosing the location for which it is required.
Re: Will it manage?
Not me. The OP evidently wasn't sufficiently motivated to do some research before posting his query.
Re: Will it manage?
I also noted Posts: 1 - Joined: Sun Feb 07, 2021 1:40 pm- after AliExpress was mention.
Re: Will it manage?
It could be innocence. But now I kinda feel like an accomplice...
But I wanna talk about Glenn's post. Why not just whittle away in small bits?
Re: Will it manage?
Depends on one's circumstances. If the project is for pay, you wouldn't be competitive, and scratching away at a part when a single pass would work gets old real fast.
Making only one off? Doing it for pleasure, not for gain? No big deal.
I shudder to think of making hundreds of parts by the scratch method. YMMV.
Re: Will it manage?
The machine in question looks to be a CNC router table, and it would appear that the person asking the question has little to no experience with machining or they wouldn't be asking.
Chip welding while milling aluminum is real, and can be a considerable issue with smaller end mills, especially if you have never milled aluminum before. Once you have used flood coolant for milling, turning, or grinding, there is no going back to dry machining if your interest is in getting the job done efficiently...
Re: Will it manage?
Heh! I can't even imagine grinding dry. I've done it, and the problems created are insurmountable. Truth is, some operations are simply not possible without flood coolant. A centerless grinder comes to mind---as does cylindrical grinding of 300 series stainless. It can be hard to grind *with* coolant.
