Steam railroading to return to Alaska!
- Dick_Morris
Re: Steam railroading to return to Alaska!
The Alaska Railroad can turn wheel sets with outside bearings and they assembled and machined the wheel sets on our tender trucks. However, they no longer have a capability to mount the 33" wheels and axles with inside bearings as is used on our lead truck. We contracted with Alaska Roteq to turn the journal surfaces and re-profile the wheels. They have extensive expertise on rotating equipment such as large pumps and they are only a half mile from the 557 Engine House.
There are a couple of interesting features of the set up that could be used in our size - the cardboard shield to protect the bearing surface and the layer of some kind of slippery plastic under the steady rest jaws.
Now that's a BIG lathe!
Dick,
The slippery stuff under the jaws of the rest is a common dodge. An old time machinist told me about that trick and where to get the slippery stuff. I cut strips out of old TIDE detergent bottles that my wife supplies! It works great.
Keith
Keith
I never liked a steady rest that would grind on the metal being turned, I use teflon sheet.
- Peter Crisler
- Dick_Morris
The June status report has been posted at http://www.557.alaskarails.org/restore/ ... index.html. Despite the challenges of COVID-19 we are making good progress.
Among the parts that are nearly ready for installation are the side rods with new bushings. We are looking forward to the return of the driver journal boxes from a Lower 48 contractor so we can finally put the wheels back under the locomotive.
Exciting progress!
Once you get the drivers back under the loco I expect there will some celebrating going on!!
I've experienced that.
- Dick_Morris
The July status report is posted at http://www.557.alaskarails.org/restore/ ... index.html.
More tools to add to the collection of what is needed to maintain a steam locomotive. Two pressure gauge dead weight testers, one an Ashcroft, the other an Ashton. Why two? The Ashcroft, original to the Alaska Railroad, lost its weights somewhere before we got it. We were able to obtain the Ashton at a reasonable price and it ls complete.
Dead weight tester weights show up on ebay pretty regularly, the sellers have no idea what they are however!
- Dick_Morris
The newest status report is posted at http://www.557.alaskarails.org/restore/ ... index.html.
I missed announcing the posting of last month's report. It is at http://www.557.alaskarails.org/restore/ ... index.html.
It takes a lot of parts to make up the suspension. Every hole has been bored oversized and fitted with a case hardened bushing, per the original plans. Almost every other part required some type of attention, up to fabricating a replacement.
We have kicked off our 2020 fund raising campaign. Five supporters have established a $50,000 matching challenge (including yours truly being on the hook for $5,000). We would welcome your contribution and I would welcome you making some of my $5,000 available to the restoration. Information on contributing by check or on-line can be found at http://www.557.alaskarails.org/support/donate.html.
- Dick_Morris
A special December status report on the overhaul of Alaska Railroad #557 is posted at http://www.557.alaskarails.org/restore/ ... index.html
A view looking down on the turret shows another place where one of Anthony's U-joints can be used, the main stop valve used to cut off steam to all the accessories piped from the turret.
Indeed! Looks like a LeBlond.
Dick, do you know if it is?
