New York Central J1e
- Trainman4602
Re: New York Central J1e
The cut out cocks were used on the front of a locomotive. The two hoses were the train line and the straight air. Both used when two locomotives were coupled for double heading. This is how they were placed on the K4
- JBodenmann
Hello My Friends
Thanks for all the info concerning brake hoses and such. The brake hose and signal line on the pilot have been fitted up with two different sizes of hose and glad hand. New York Central had their own way of doing this, photos coming soon. Little bits are being added, here is one. An air pump governor was slammed together and stuck in the steam line. Just another little trinket to add to the clutter.
- JBodenmann
One more little bit of baloney , just slammed together with some brass and silver solder. This little guy sticks to the trailing truck booster steam line just in front of the cab on the fireman's side. More to come.
Jack
Jack
- JBodenmann
Hello My Friends
Here are a few more. The Barco low water alarm is missing the whistle flange and the line to the lower boiler connection tee. Currently waiting for the Commonwealth tender truck brake rigging castings. Jim Kreider sent some beautiful castings for the tender brake cylinder that will be machined up next week.
See you in the funny pages..
Jack
Jack
jack just out of curiousity, i see you have the scale whistle on top inside of that shield or trough thing what ever they called it on hudsons. but i don't see where the big whistle is and im assuming like the berkshire's that the only place you could put it was inside the wheel frame?
just curious on that and keep up the good work she is looking great.
- JBodenmann
Hi Dan
The J1e will have one of Jim Kreider's berkshire whistles hidden down between the frames.
Jack
Jack
Jack, this is absolutely stunning work that only a master like can create! When will it's first run going to be? Oh how do the Jim Krieder Berk Whistles look like? Thanks and Keep on Steamin' my Friend.
David
David
The 1" Scale Junkie ... But steam of all sizes is cool with me!!
"If you can dream it, you can do it" - Walt Disney
sweet keep up the good work.JBodenmann wrote:Hi Dan
Jack
- JBodenmann
Hello My Friends
Here are a few snappies of what's been happenin' with John's Hudson. The first is a look at some little gauges and lamps that the little elves make up here in the shop. The ones on the left are some tiny gearless gauges that Ashcroft makes. They only cost around $9.oo ea. They are just plastic but some little housings with lamps are made up that they will fit into. As the gauges come from the store they have 1/8" male iron pipe thread fittings out the back which are changed to little compression fittings for 1/16" tube. The two gauges mounted to the plate will be for main reservoir pressure and independent brake line pressure. The upper center left lamp is just for general cab lighting and the upper right lamp is for water glass illumination. These lamps are set up to use 1/8" continuous spring for flexible conduit. Once again, if there is sufficient interest I will offer these items for sale. And lastly, on the right is a beautiful All American pressure gauge available from our good friends at American Model Engineering. This gauge has been modified with a little lamp housing stuck to the top.
- JBodenmann
And here are the gauges in their natural habitat, a locomotive cab. Too much fun!
Jack
Jack
- JBodenmann
Here is another little trinket. Brad worked his usual magic with some masters that were sent him and sent these lovely castings. Some little square bead bolts were made to hold the things together, and Bob's yer' uncle. Modern steam had gaggles of these little blobs and bits and that's what makes it so cool. If you would like one of low water alarms, check out the for sale section.
Jack
Jack
How does the low water alarm detect a low water level on the prototypes?JBodenmann wrote:Here is another little trinket. Brad worked his usual magic with some masters that were sent him and sent these lovely castings. Some little square bead bolts were made to hold the things together, and Bob's yer' uncle. Modern steam had gaggles of these little blobs and bits and that's what makes it so cool. If you would like one of low water alarms, check out the for sale section.
Jack
