Seal options for boiler feed pump?
Pwallace
Post by Pwallace »
I am looking to repair a March boiler feed pump that is feeding an ottaway steam train in Northern California.
The steam side is 1.5” diameter and the water side is 7/8”. It’s apart at the moment so I do not have the stroke measurement.
I like the method in the Artisan steam engine piston rings using carbon filled PTFE but I am not finding material this offered at the common vendors in the 1” size. I have a mill and lathe of reasonable capacity.
It looks like this question about availability is posted every few years so this is my turn and I am interested in sources and alternatives.
The water side looks like cast iron with a very loose fit. The pump runs but it’s not filling the boiler so I would like to start with rings and then move through valves and plumbing.
Re: Seal options for boiler feed pump?
Post by Bill Shields »
Use square braided packing and cut rings to fit.
Or use graphite tape and wind it around to fill the gland.
Been working for 100+ years, no reason to reinvent the wheel.
David Powell
Post by David Powell »
For soft packing to have a long life the piston it is fitted on should fit the bore with no more than about 5 thous total clearance, preferably less.
Regards David Powell
Glenn Brooks
Post by Glenn Brooks »
Can you post photos of the pump? The only feed pump on my Ottaway is a 1” cylinderical pump mounted behind the port cylinder, next to the smokebox saddle. Never knew of a different style pump…
Pwallace
Post by Pwallace »
It looks link I am able to post photos. I figured there would be post limits.
This ottaway lives in the Bay Area and this March pump was a gift from one of the steam clubs in place of the injector. It’s not original and it struggles. I am hoping new rings help.
I will measure the grove and try to find packing. This is the water side and the existing rings look like cast iron.
I would still like to build the ring for fun but cannot source graphite filled ptfe or substitute.
Pwallace
Post by Pwallace »
Glenn Brooks wrote: Thu Dec 08, 2022 12:35 am Can you post photos of the pump? The only feed pump on my Ottaway is a 1” cylinderical pump mounted behind the port cylinder, next to the smokebox saddle. Never knew of a different style pump…
My understanding is that the small inboard piston on the port side is part of the optional air brake system.
