Driver wheels profile
- makinsmoke
Re: Driver wheels profile
Assuming the rail profile is the same in various sizes, then the wheel profile should also be the same.
It’s the rail the wheel must match.
as usual...i knew that I thought I was saying but was not clearly stating what I wanted others to read.Harold_V wrote: ↑Mon Sep 26, 2022 4:19 amOk, now I get it. When reading your comment it was easy to think that the profile wasn't important, not that the difference between 1.5" & 1.6" didn't matter. I fully agree with that, as the track on which they run is the same.Bill Shields wrote: ↑Sun Sep 25, 2022 4:31 pm yes...i am sure...profile is the same for 1.6 / 1.5
if someone had wide and square flanges, they would not be correct for either 1.5 or 1.6
this is not necessarily true - unless you are restricting comment is referring only to angles and internal fillets.....makinsmoke wrote: ↑Mon Sep 26, 2022 12:40 pm Assuming the rail profile is the same in various sizes, then the wheel profile should also be the same.
it is not just the rail but the other parts of the track that have to accommodate the flange height, flange width and back to back dimensions that have to be correct.
I have a 2.5" GAUGE loco that runs on the same RAIL as the 4-3/4" GAUGE RIDING CAR..but the flange dimensions (width and height) are very different to accommodate guides, frogs, etc....
these are the parameters i use when i machine wheels, I likely have over 100 wheels under my belt,
1) back to back. 7.120 to 7.125
2) 7.45 to 7.5 at the top of the fillet
3) ~10 degree taper on front and back of the flange
4) cut a radius to join the front and rear taper.
5) flange height of .150
some notes, #3, the front tape may need to be adjusted depending on wheel diameter and tightest radii this wheel will see.
I do not have issues with tracking following these parameters.
Wow, sorry I don't understand any of that.
- Greg_Lewis
Emfinger:
Here is a pdf of the IBLS wheel profile for 7.5 gauge, and a link to the page where all the various profiles are listed. This shows the tread and flange profile for each wheel as well as the relationship between the two wheels on the axle.
http://ibls.org/mediawiki/index.php?tit ... l_Standard
use them for dive weights?cbrew wrote: ↑Mon Sep 26, 2022 1:12 pm these are the parameters i use when i machine wheels, I likely have over 100 wheels under my belt,
Want to make it 104 ?
unfortunately, I am so far behind on other projects, not at this time,
so i have to ask, why are you looking at the wheels, is there a tracking issue?
I have 700+ wheels under my belt. PM me if you want.
I recently added a CNC lathe to my shop and tire profiles are a snap on it.
Andy Pullen
Andy Pullen
Andy haas the way to do it
Good one, Bill
Being from the old school of machining, I have a hydraulic duplicator (poor man's CNC) on my Graziano. It was purchased many years ago to fulfill a government contract for more than 600 main landing gear spacers for the C-130 aircraft. A 5/8" X 45° chamfer on the ID plus a gentle taper terminating in a large radius (on the OD) were required, each of which pretty much mandating the use of a machine capable of contouring. This was long before the advent of CNC's. They had a couple tight tolerances, each handled in stride by the duplicator.
While I have yet to use it for profiling a wheel, that's precisely what I'll do if I happen to get to the point where I have need. Once set up, it should be just as fast as a CNC.
