Brake valve ID help
Brake valve ID help
Hello does anyone recognize who made this brake valve its in my 1.5 scale little engines 0-6-0?
Re: Brake valve ID help
That looks like one that Fred Bohn used to make.
- Joe Tanski
Yes that is a Fred Bohn Brake valve,he developed it for his 999 train brake system
Does anyone make a version like that today?
yes and no,
two have been made, trying to talk him in to making more to go with his train valve
There's this link I have saved:
https://www.chehalemmachineworks.com/
No idea if they are still making them etc.
Then Jack B on here has made some really nice looking 1.5 scale units.
Really like how Paul Keiser did a brake standing using the RRSC or maybe now Mike V castings and putting clippard valves on a cam under it. very slick.
- makinsmoke
Railroad Supply still sells that cast brake stand.
I believe they now utilize the Clippard setup.
Wish someone made and sold the cam plates for those of us without the skills.
The great thing about the clippard setup is that if the valve starts giving you problems you can just order a new one for $25 and swap it out. Agree on the cam under it, not sure what the easiest way to make that would be.
Layout die, drafting tools, belt sander and file
Not rocket science..
I would love a couple of Jack’s but he isn’t making them at this time and I missed out on the last run.
Maybe he will start up again
And why are these so special?
Thanks,
SteveR
Thanks,
SteveR
12x36 Enco Lathe, 9x42 Bridgeport, SMAW, O/A, Miller MIG w/gas, plasma
Not enough measuring tools...
1.5" Allen Models Consolidation on air.
1" FEF in progress
1" & 3/4" LE Projects
Measure twice, cut once, wait - it was supposed to be brass!
1" FEF in progress
My first setup was a pair of Clippard regulators on cams, they worked great for straight air. but since i did not have any detents. not so well with auto. the vibration of rolling down the rails with the spring pressure would force the cam to turn, creating a reduction in the brake pipe.
