How to make sure your injector will always work
- AnthonyDuarte
From my observations over the years:
The single most important part of an injector installation is the section between the injector and the tender water valve. It has to be simple and absolutely air tight with the least amount of joints or fittings possible. If this section is not well done it will inevitably lead to problems.
Oddly this portion seems to get a little neglected on many miniature models. That's not meant as a putdown, and it's understandable. You put a lot of hard work into getting a nice looking delivery line from the injector to the boiler; blood sweat and sometimes tears go into figuring out how to get a steam line from your turret to the injector, and after spending more time and money on fittings and copper tubing than planned, there's not much energy left to think through the connection to the tender. There's a tendency for it to be a bit jerry-rigged just to get water from point A to point B, but it's the most critical part!
I'm thinking of some possible products to make connecting injectors to the water feed a little easier, but in the meantime, treat this part of the installation with the upmost care for the best possible operation of your injector!
A tight water line with an appropriately sized filter will give you endless hours of trouble free operation. And if you thoroughly blow the injector out with air at the end of the day, the washer won't get stuck, leaving very few reasons to ever have to take the injector apart.
Anthony
P.S. don't put your injectors on a cleaning schedule. Take them apart if they're not working, otherwise it's best to leave them alone
Anthony
Re: How to make sure your injector will always work
What's the best way to blow air thru the injector, and dry the water out?.....the overflow pipe???
- AnthonyDuarte
The best way (if possible), is to blow air through the steam line with the water line disconnected. This will dry out the inside of the injector without risking sucking in more moister from the water line. I pressurize my boiler with air at the end of a meet to do this.
If that's not possible, blowing air through just the water line will get the bulk of the water out as well. Blowing through the overflow pipe won't do any good. Since it's a check valve, the air won't make its way into the injector.
The injector body can be full of water, and continue to collect water as the steam condenses at the end of the day. The nozzles then sit in a pool of water that leaves deposits as it slowly dries over months of sitting. If everything is dried out ahead of time, this won't happen.
What is your view of connection products? I'm meaning types of quick connectors or other couplings for folk that must detach the tender after running.
-ken cameron
mailto: kcameron@twcny.rr.com
Wave a magic wand at it..
All my connectors between my tender and injector are traditional style model engineer cone unions. I made them all myself, so, they are nothing special. They must be air tight, any air leaking into an injector water line will spoil the function of an injector. Cone unions are easily made airtight and there is no need to over tighten to make them so. I remove my injector at the end of the season and blow it dry and store it in the tool box until next season. A week or two stored wet is probably OK, but, not for months.
Very good advice on blowing the injector dry with air thru the steam line. I will start doing this as it is much easier on me (and the injector) than taking it apart and cleaning it. Thanks again, Anthony.
- Benjamin Maggi
That is a bit easier to do on a tank locomotive!
Thanks, Anthony......good information to know. I recently went thru all this, and replaced my tender valves, when I found the packing nuts were loose, and drawing in air.
I just inquired with Eccentric Engineer about the medium size injectors which were in the catalog. Presently, they are sold out and there may be a very limited run sometime in the future. I've made it clear that I want one. If you are thinking about the same, you might let the manufacturer know now.
be sure to call TicketMaster to get a reservation
the devil made me do it
How do you all feel about Lifting injectors instead of the gravity fed ones?
-Chris Srch---- Home track Tradewinds and Atlantic Railroad
