Tapping Boiler shell directly
Are there any issues with drilling and tapping a boiler shell directly without a welded bushing to add a water inlet? Probably 5/16 mtp or 1/8 npt.
Re: Tapping Boiler shell directly
Depends on the shell thickness and shell curvature and operating pressure and shell material and ??. 1/8 NPT has 27 threads/inch and I would want at least 6 full threads myself for a 1/8 NPT fitting into steel at 100psi (just a guess) Small radius shell would have a thread engagement different from a flat plate, such that you might need even more threads. Alternative to contiguous welding, you could tack weld and then braze/silver solder a bushing to get the extra threads and simplify.
Good luck,
SteveR
Good luck,
SteveR
12x36 Enco Lathe, 9x42 Bridgeport, SMAW, O/A, Miller MIG w/gas, plasma
Not enough measuring tools...
1.5" Allen Models Consolidation on air.
1" FEF in progress
1" & 3/4" LE Projects
I'm thankful that metal is recyclable....
1" FEF in progress
10 inch pipe, 10 3/4 OD, sch 40.
- Chris Hollands
FYI - this is from the Australian model steel boiler code -
Tapped holes for bolted or studded connections shall have sufficient depth to allow a minimum length of threaded engagement equal to the major thread diameter - this would be for smaller taper threads as well I'm guessing .
If it is 10" schedule 40, that means it has a wall thickness of almost 3/8 of an inch (0.365" I believe), so that is plenty enough depth to drill and tap directly into the shell for certain sizes. 1/8" NTP and 1/4" NTP will be fine to tap at that thickness, you won't have any problems with leaks or anything unless you mess up the threads somehow. Anything larger might require a bushing of some type. I've never had a problem with any of the threads that I tapped into that. Using 1/4" wall thickness, I usually weld in a bushing. I've also seen people 'build up' the surface by about 0.100" by welding, and then drill/tap a 1/8" NTP in the middle of that.
Thanks for the replies! That's what I thought but wanted to be safe. Don't have a TIG so didn't feel comfortable doing the bushing welding.
And what do you think we all did before TIG was available?
We stick welded everything
Your pipe is more than thick enough to stick weld a bushing in place.
Having spent most of my life around industrial boilers, I have an aversion to threading directly, although I know it is a common practice in the live steam hobby world.
Some quick work in Fusion - using 28 TPI straight thread.
Your case: 6 inch copper "L" type
1" FEF in progress
1" FEF in progress
sch 40 pipe, i would have zero issue up to 1/8 npt. plenty of meat for proper thread engagement
One more caveat for this - if you're tapping pipe thread, don't tap as deep as you normally would. You want to make sure it snugs up good and tight.
SteveR
SteveR
1" FEF in progress
1" FEF in progress
