Gaskets for small surfaces
Making progress on installing a new boiler on my Allen engine but looking for suggestions on "how to".
Before starting the boiler replacement project, I had a problem with the stem on the blowdown valves leaking. I removed the valve and replaced a dried o-ring and reassembled and reinstalled the valve. It now leaked between the two halves of the valve body. The original valve had no gasket, so I initially tried some RTV rubber which did not work. The problem is that the surfaces are so narrow a traditional gasket does not seem to work, the gasket material just gets pushed out. Next option seems to be to try to lap the parts together, but I see the possibility of making things worse. I also considered using Loctite has anyone had experience trying this any other suggestions?
Re: Gaskets for small surfaces
I use number 2 permatex on everything
take a THICK piece of glass and some 2000 grid wet sand paper (used to auto painting)
using a water, likely lap the mating surfaces. use bluing to so you can see the surfaces are true.
then reassembly
then reassembly
Use a very thin, stiff gasket material such as printer paper. Leave a lot of overhang on the outside and trim it off after assembly.
What CBrew suggested.
I always lap the blowdown valve halves on a flat plate when servicing them. It is easy to see when the surfaces are shiny flat.
They always seal perfectly that way.
Are you sure that there was not a thin copper ring on the inside?
Hi,
CBrew is right, but instead of sandpaper, use polishing paper because it is thinner. I use 400 grit, but while it works, something finer would be better and I use it on a surface plate (because I have one). If you don't, glass is a good substitute. While it may be obvious to most, make sure the abrasive side is up.
I don't use gaskets, I use the lapping method instead and it always works. It doesn't take very long either and when you are done, you will have a mirror surface on the part.
Richard Trounce.
Richard Trounce.
likely just used the wrong term, i use four stages when i lapped my valves surfaces, started with 400, 800, 1500 and 2000 grit.RET wrote: ↑Sun Jan 16, 2022 5:34 pm Hi,
Richard Trounce.
Hello Good People ,I have used glass plate, comet and diesel fuel. That is what we lapped fuel injectors on older Mercedes diesels
