Wiha nut driver set question
Re: Wiha nut driver set question
I got mine from McMaster-Carr. Item - 52965A15. The online catalog does not have the Wiha name displayed on them, but when they arrived they are indeed Wiha and the name is on the Handle. That was a couple of years ago, not sure if they changed suppliers.
Micro-Mark tools also sells them:
https://www.micromark.com/8-piece-Preci ... Metric-Set
- makinsmoke
Dick,Dick_Morris wrote: ↑Sat Dec 25, 2021 1:16 amI have a set of the short nut drivers with clear red handles that I got 40+ years ago from Cole's, but the connection between the handles and shaft wouldn't withstand as much torque as I tried to use. Those from Wiha are much better made.
I have that same set, bought eons ago, and the driver shaft has gone a bit loose in the most used one (#5), but so far none have failed.
GWRdriver
Nashville TN
Nashville TN
- Gary Armitstead
Jack,
Amazon has a Whia 4.5mm X 60mm nut driver for $10.
https://www.amazon.com/Wiha-Driver-Prec ... 35&sr=8-19
Gary Armitstead
Burbank, CA
Member LALS since 1980
Member Goleta Valley Railroad Club 1980-1993
Burbank, CA
