looking for long life light bulb
Re: looking for long life light bulb
Interesting...could stuff 3 of them in the firebox...thx
Or these ceramic infrared 50W heater bulbs with standard E27 screw base:
https://smile.amazon.com/Wuhostam-Ceram ... 465&sr=8-6
$13 for 2.
Many other options also shown.
I may get them to mount under the firebox propane burners of my two locos.
$13 for 2.
Those burners will not fit thru firedoor
I figure by the 4th page, you guys have fingered a solution, and I know some on the board are not a fan of conspiracy theories, but this one is pretty good...
Not even these small diameter (2.16") ones?
https://smile.amazon.com/dp/B0819KRG7Q/ ... s9dHJ1ZQ==
Unfortunate.
Bill,
I suspect you're already aware of these, but if not then you may want to take a look at the 75W 120V 2-pin halogen T4 bulbs and their bulb-holders. I used to use one of those inserted through the firehole door before I switched to the magnetic heaters. They give off a lot of heat for their small size.
Best regards
Best regards
Russ:NP317 wrote: ↑Fri May 14, 2021 10:03 amNot even these small diameter (2.16") ones?
Unfortunate.
no...I don't have 2.16" clear....
