Cucumber Coal
Moderators: cbrew, Harold_V
Fender
Cucumber Coal
Post by Fender »
Has anyone bought coal from Bay Star Coal in Cucumber, WV lately? I had heard good things about their coal a few years ago, and bought several tons. Turned out that they had switched to a different mine, and the coal did not meet my expectations. What are they selling now?
Dan Watson
Chattanooga, TN
kbarnett
Re: Cucumber Coal
Post by kbarnett »
The last batch we got from Cucumber was 2 years ago, it was good coal, no smoke, very hot, but seems to have more slate and a higher ash content than in the past.
Fender
Re: Cucumber Coal
Post by Fender »
Thanks. I can deal with ash, so long as it doesn’t clinker badly. The coal I bought, frankly, didn’t burn well at all.
Dan Watson
Chattanooga, TN
SteveR
Re: Cucumber Coal
Post by SteveR »
What does this mean? Coal is a complicated material.
SteveR
12x36 Enco Lathe, 9x42 Bridgeport, SMAW, O/A, Miller MIG w/gas, plasma
Not enough measuring tools...
1.5" Allen Models Consolidation on air.
1" FEF in progress
1" & 3/4" LE Projects
I'm thankful that metal is recyclable....
Fender
Re: Cucumber Coal
Post by Fender »
Steve,
It just didn’t burn well in my boiler. It acted more like anthracite than soft coal. Very little volatiles and the coal didn’t break apart in the fire.
Dan Watson
Chattanooga, TN
kcameron
Re: Cucumber Coal
Post by kcameron »
Intended use makes a big difference in which type of coal you like. When I'm blacksmithing, I like one that has a medium clumping (sticks together) as I can mound it or even make a cave of heat for some operations. I get better work if it is near anthracite but too close to anthracite it is hard to start and keep burning well. The nearer to anthracite has less ash when burnt and cleaner burning. In the loco I don't want any clumping, unless it is a very small grind when that helps it from falling through the grates. Going too far the other way from anthracite you get more smoke and I think it is a bit more acrid and bothersome to the eyes. Worst in both of my uses is stone or any non-burning material in the batch. Screening it to pick some of that out is needed sometimes.
But the biggest deciding factor for most people is what ever type of coal they can find. Lots of areas have few choices. Luckily in upstate NY we have a number of coal users ranging from blacksmiths to Amish families. Sometimes you may even find that blending sources will give you what you want.
-ken cameron
mailto: kcameron@twcny.rr.com
Fender
Re: Cucumber Coal
Post by Fender »
Ken,
I bought some coal about six years ago from a dealer in South Boston, VA that was just about perfect. Low smoke, little ash, hot, no clinker. But, it had been dug out of a cellar, so was a finite supply. Still trying to find the “holy grail” of coal sources.
Dan Watson
Chattanooga, TN
Marty_Knox
Re: Cucumber Coal
Post by Marty_Knox »
Dan did you get a copy of the analysis of the coal you bought? It is customary for the supplier to provide one when asked.
What you want to look at are the BTUs, the % of volatiles, and the ash fusion temperature.
Berkman
Re: Cucumber Coal
Post by Berkman »
Re: Cucumber Coal
Post by Bill Shields »
penncoal -> yes...frequently
generally it is quite good...but then...on occasion get something less than expectations.
happens with blaschak (which I use to heat my house)...99% of the time it is just fine...then i get a couple of bags that won't stay lit and have a bunch of slag (shale / slate)? in it.
is nature of beast
Fender
Re: Cucumber Coal
Post by Fender »
Marty_Knox wrote: Fri May 07, 2021 10:17 am Dan did you get a copy of the analysis of the coal you bought? It is customary for the supplier to provide one when asked.
Marty,
I didn’t get (nor ask for) an analysis. I was just going with the recommendation of another live steamer. I learned later they were getting their coal from a different mine.
Dan Watson
Chattanooga, TN
pat1027
Re: Cucumber Coal
Post by pat1027 »
Berkman wrote: Fri May 07, 2021 10:18 am Anyone used penncoal? http://www.penncoal.com/blacksmith-live-steam.html
I bought 20 bags in 2019. What I have burned so far is comparable to other the "Pocahontas" I've burned. It tends to clump up which is desirable for black smiths. I notice clumping less with larger pieces. The clump needs to be broken up after it has started to burn. What I don't like about black smith coal is the percentage of fines. I run mine across a 1/4" hardware cloth screen and loose maybe as much as 25%.
