Page 4 of 4
Re: Pre-heating boiler water
Posted: Sat Apr 10, 2021 8:16 pm
by James Powell
1/8" copper tube offers a lot of resistance to flow even in a 3/4" model...you can do the calculations for velocity of the water and the resultant losses, but they will be substantial for a 1" or 1.5" model.
I would go with something like 1/4" copper tube (about 4x the area, or 1/4th the velocity & pumping losses).
We have fitted steam:feedwater feed heaters before- on a Stuart #9 with the 504 boiler. It was very marginal with the spirit burner without the feed heater, and a lot more comfortable with it. I would guess that as posted upthread, on a marginal boiler the added energy that you can recover with a feed heater is probably worth it. The same thing is true on full size, where a gain of a couple of .1% of n spread across all the locos could exceed the fuel costs difference. Here at work in a heating plant, we have preheaters running exhaust: water.
On the ship, running with extraction on the turbine (typically at the cross under pipe, so HP extraction not LP), the difference was about 4% _plant_ n vs using boiler steam for preheating (285F/33-38 PSI). At 10 000 hp, that was a substantial amount of fuel, and far more if we were at 21 000 shp and getting it off the LP turbine (about 5% n, from ~28-> 33% n overall)
Remember the above is on turbines running extracting steam into a pressurized hotwell, which is NOT what we would have on a railway engine.
James
Posted: Sat Apr 10, 2021 8:50 pm
by Berkman
Every oil fired 7.5 gauge loco I've seen has the exhaust steam plumbed up the exhaust nozzle just like the real ones. Nothing wrong with the change in draft, just design the front end arrangement with oil firing in mind.
1/8 is way too small.
Posted: Sun Apr 11, 2021 11:18 am
by Emfinger
The axel pump that I have has two check valves with an 1/8" diameter seats. That is why I picked 1/8" (ID) tubing.
Between the firing valve, my blower control valve and the atomizer flow control (pressure regulated) I can go from just burning to a roaring blaze and anywhere between. I don't need or want the exhaust to be part of the burner control. If I were burning rocks I would want more draft when the throttle is opened.
Posted: Sun Apr 11, 2021 4:28 pm
by Bill Shields
1/8 orifice is very different than 1/8 pipe.
Theoretically it will work but will create a lot of back pressure and the water rushing through will not get as warm as if it were passing through a larger pipe at lower velocity.
Posted: Sun Apr 11, 2021 7:01 pm
by Emfinger
Bill Shields wrote: Sun Apr 11, 2021 4:28 pm 1/8 orifice is very different than 1/8 pipe.
This tubing is 1/8" ID just like the check valve
Posted: Sun Apr 11, 2021 7:11 pm
by Bill Shields
You will do better with larger tubing...but if that is all you have..
Posted: Mon Apr 12, 2021 9:57 pm
by Berkman
No doubt cost is a major problem, but wouldn't something like monel be a decent solution.
Posted: Mon Apr 12, 2021 11:30 pm
by AnthonyDuarte
Having one or two points with 1/8” ID is ok, but you shouldn’t size your tubing based of the internal bores of your check valve. Restriction increases with the length of the tube in addition to the diameter. Think about how easy it is to suck air through a straw. Make that straw 3 feet long and see how easy it is... (spoiler, it’s not).
Probably want 1/4” as a minimum.
Posted: Tue Apr 13, 2021 4:45 am
by Bill Shields
Monell is not the best for thermal conductivity. It is slightly better than stainless.....but nowhere near as good as copper.
If you ate going to do it for the purpose of heating water then use some good basic thermodynamic principles..just make it easy to remove and repair and stay out OJ f the way for routine maintenance
Posted: Thu Apr 22, 2021 10:09 am
by Emfinger
Got it guys, going with 1/4" copper.
Thanks to all.
Tom
