Rod material
Rod material
I’ve noticed some bigger designs call for 11L17 for driving wheel rods. Have been using A36 hot rolled in past. Advantages?
Mountaineer
Mountaineer
Re: Rod material
Well, this is interesting.
I googled "11L17 vs a36" and got this:
https://www.makeitfrom.com/compare/ASTM ... rbon-Steel
Nice comparison between two materials.
These two look pretty similar, but 11L17 has greater fatigue strength and tensile strength, which I suppose would be important for rod material.
Also, the L stands for lead, which makes for a better machining experience, although you'll have to add a proposition 36 warning in California
Re: Rod material
Here goes:
CAUTION:
California centaines Proposition 36 warnings!
CAUTION:
- Dick_Morris
Re: Rod material
From the Speedy metals site - "Because of the addition of lead in 11L17, its weldability is also poor." Not applicable to rods, but might be to other applications.
Re: Rod material
From what I’ve seen, leaded steels also seem to “rust” faster than non-leaded steels such as A36 or 1018.
Dan Watson
Chattanooga, TN
Chattanooga, TN
- Dick_Morris
Re: Rod material
I was going to include that as a recollection in my comment, but I couldn't find verification in my quick check of the Internet.From what I’ve seen, leaded steels also seem to “rust” faster
Re: Rod material
1144 would be a good choice for rods. High strength and good machinability.
Nyle
Nyle
Re: Rod material
Agree with above. I have some 12L14 I bought, it rusts like crazy. And it is soft. The 1144 (stressproof) would be a very good choice, it also "moves around" very little when machined, as there are lower internal stresses. I made my frames out of hot rolled 1144 P&O (Pickled and oiled) - the P&O gets rid of the "bark" that you find on most hot roll.
In general, hot roll has lower internal stresses than cold finished.
Re: Rod material
That is very important in milling as in this application.
You will be removing metal from one side and then you find that the part warps when you take it out.
In turning, it's not as much of a problem because you are removing metal symmetrically.
Re: Rod material
The use of Stressproof, unfortunately, is limited to hex or round bar stock. To my knowledge, it is not available as flat stock.
If I am not correct, would someone please correct me, and provide a source for such material?
Re: Rod material
AISI 1144 is not "stressproof."
Genuine StressProof® is a registered trademark of Niagara LaSalle and refers to a processing method, not the material. StressProof is AISI 1144 that has undergone a series of heat treating and cold working steps to improve dimensional accuracy, toughness and decrease internal stresses. Purchasing 1144 from your favorite supplier will not get you genuine StressProof unless you order it and pay accordingly (genuine StressProof will come with paperwork from Niagara LaSalle). Also, don't let them try to sell you ASTM A311 and claim it's StressProof.
Re: Rod material
Genuine StressProof is only available in rounds and hex stock. I've not seen anyone selling AISI 1144 in flats.
