New line of SCALE wheels
Moderators: cbrew, Harold_V
What size Wheels do you need?
Poll ended at Wed Apr 07, 2021 12:21 am
IBLS Flange
10
38%
Quarter or 25 Flange
0
No votes
1.5" Scale 33" (WHF1533)
6
23%
1.5" Scale 36" (WHF1536)
5
19%
1.5" Scale 40" (WHF1540)
1
4%
1.6" Scale 33" (WHF1633)
1
4%
1.6" Scale 36" (WHF1636)
1
4%
1.6" Scale 40" (WHF1640)
2
8%
Total votes: 26
David S Coster
Post by David S Coster »
I am working on doing a new line of Wheels and Axels for Accucraft. I have done the drawings for a Forged wheel in scale sizes. 33", 36", and 40" for both 1.5 & 1.6 scales IE: six drawings. We should be able to produce them for under $25 a wheel, just how far under depended on demand. So I am going to ask for your opinion on what ones we should stock and what one will be for special orders. I have also done the axels for these wheels. There is a universal axel for both 7.25 / 7.5 it can be set for either, as well as one for each gauge. We will be offering the wheels in the new Quarter inch flange that was developed and freely distributed by that three letter company I used to run. Sorry I can't say their name, you know the one. Hence forth I will be calling it the Quarter or 25 Flange. Please select one flange type and up to three wheel sizes that you would use. This is marketing research that will help in bringing new products to our hobby.
You can find more information on my FACEBOOK page 'David Coster'
Thank You, David Coster
This is the front view of WHF1633-I
This is the Back view of WHF1633-I
This is the cross-section of WHF1633-I
Andypullen
Re: New line of SCALE wheels
Post by Andypullen »
What is the 1/4 flange?
What material are these going to be made of?
Castings or forgings?
pat1027
Post by pat1027 »
Andypullen wrote: Mon Mar 08, 2021 8:18 am What is the 1/4 flange?
I'm guessing it's this. https://www.rmirailworks.com/RMI-25_Whe ... EZmJ2hKiUk
David S Coster
currently cnc machined
David S Coster wrote: Mon Mar 08, 2021 11:08 pm currently cnc machined
That doesn't answer the question that was posed. Cast wheels, forged wheels or even wheels made from bar stock could be CNC machined.
Andypullen
Harold_V wrote: Tue Mar 09, 2021 3:42 pm
Amen Harold.
The 1/4 flange would be way out of scale for 1.5” and 1.6” scale wheels. They would be better on the larger scales like 2.5” and bigger.
As I’m not building anything bigger than 1.6” scale; I won’t be needing the taller flanges. I personally prefer to turn my own wheels.
David S Coster
We are offering both flanges. The reason for the taller flange is it tracked better and dose less damage to the rail! As for scale, because of the center of gravity of the scale equipment let alone with riders on the cars, true scale wheels and be problematic, The I.B.LS. is not true scale either, It was a compromise by all the manufactures way back when.
jeffsmith
Post by jeffsmith »
Why can't you design something that looks like the prototype? The cross section is way different from the prototype. Should be a hub on the back protruding about a 1/4" for a longer engagement with the axle and the front hub should be recessed about 3/16" so the journal box sits closer to the wheel center. My 2 cents.
LIALLEGHENY
Post by LIALLEGHENY »
Yes I also would like to know, castings, forgings or bar stock? And what alloy?
Nyle
