Minimum radius
hoppercar
Minimum radius
Post by hoppercar »
How do you determine the minimum radius required for an 1 1/2 scale locomotive, to determine if a blind drivers would be needed,?...is there a quick and simple formula ?
Re: Minimum radius
As long as you know the lateral movement, axle spacing and number of axles on the rigid frame.it is a simple CAD layout exercise.
Yes..there are formulas but I like to see it (dinosaur)
Remember...blind drivers most often also require wider tires.
Fender
Re: Minimum radius
Post by Fender »
Oftentimes, the limiting factor is not the “rigid wheelbase” (the drivers), but the “total wheelbase” (including the leading and trailing trucks), because there is not enough swing in the trucks for a curve. So you should layout a scale drawing of the engine axles and place it on a drawing of the curve, to see what the sideways displacement of the trucks would need to be.
Chattanooga, TN
STRR
Re: Minimum radius
Post by STRR »
Here are some items. There was a great article in Grand Scales Quarterly Issue 29.
These didn't attach as I wanted them to.
Good Luck,
Terry Miller
Track Radius Caculations.doc
(32 KiB) Downloaded 267 times
Minimum Radius.doc
(44.5 KiB) Downloaded 268 times
BuffaloJohn
Re: Minimum radius
Post by BuffaloJohn »
Grand Scales Quarterly Issue 29 can be found at:
http://grandscales.com/GSQ_Issue_29.pdf
wbarbe
Re: Minimum radius
Post by wbarbe »
What is the recommended clearance on each side of the track? Would a 3 foot wide right of way be enough.
Re: Minimum radius
Probably.
Depends on wide some footpegs are mounted....and how overweight the cattle may be. :mrgreen:
I have been in many locations that did not have 3 ft on the lift or transfer table...and some fellows have to pull pegs to get in and out
Greg_Lewis
Re: Minimum radius
Post by Greg_Lewis »
If you have the space, I'd say more is better. I seem to recall that Quentin once said there should always be enough room for a pregnant woman to disembark.
Fender
Re: Minimum radius
Post by Fender »
wbarbe wrote: Sun Aug 21, 2022 1:00 pm What is the recommended clearance on each side of the track? Would a 3 foot wide right of way be enough.
A 36 inch ROW only gives 18 inches from the centerline on each side. Pretty easy to snag a tree or bridge member with your knee. 48 inches is much better.
Chattanooga, TN
kcameron
Re: Minimum radius
Post by kcameron »
One idea for ROW is the width of the ballasted track plus one mower width on each side.
-ken cameron
Syracuse Model Railroad Club http://www.SyracuseModelRr.org/
CNY Modelers http://www.cnymod.com/
Finger Lakes Live Steamers http://www.fingerlakeslivesteamers.org/
Member JMRI Developer Team http://www.jmri.org/
mailto: kcameron@twcny.rr.com
In the Upstate New York US area of the world
