Driving axle box lateral
Re: Driving axle box lateral
12" radius makes no sense to me for a 7-1/2" gauge loco. I figure you have to assume opposite side movements, not just one side lifting compared to the other. Seems to me the proper radius would be whatever it is from the frame centerline to the sliding surface in question. Probably something like 3-1/2" outside lip, and 3" inside lip, off the top of my head.
I'm with asteamhead; I machined 2 degree tapers into my mikado boxes.
http://www.neidrauer.com/HeavyMikado/Se ... %20001.jpg
and then you need to think about how much actual raise the locomotive driver will see.. I mean these are one rails. not a jeep on the back roadKimball McGinley wrote: ↑Mon Mar 01, 2021 3:27 pm 12" radius makes no sense to me for a 7-1/2" gauge loco. I figure you have to assume opposite side movements, not just one side lifting compared to the other. Seems to me the proper radius would be whatever it is from the frame centerline to the sliding surface in question. Probably something like 3-1/2" outside lip, and 3" inside lip, off the top of my head.
this is just one of those "over engineering" area in the hobby imho.
