My boiler leak
My boiler leak
I got a note from someone suggesting that I try a product called "Boiler Solder".
https://www.plumbingsupplynow.com/1-lb- ... acQAvD_BwE
Sounds too good to be true...but please tell me what you think.
Thank you
Tom
Thank you
Tom
Re: My boiler leak
Looks like a product intended to get into a seam and plug it. What you have described is a hole in the tube. Doubtful it will do any good.
Re: My boiler leak
Got it !
Re: My boiler leak
I have seen (smelled) people who put crystalized ginger into a working copper boiler to plug pinholes...generally from weepy soldering.
It works...but you have to continually feed the ginger or the leaks come back...and never use it to fix a leaky tube caused by corrosion.
Generally if you have a steel boiler that has sprung a leak...it is time to pull it off and fix it
Re: My boiler leak
Research indicates that this product contains “oatmeal”! Intended for low-pressure heating boilers. I doubt that this is going to be your “secret sauce”.
Dan Watson
Chattanooga, TN
Chattanooga, TN
Re: My boiler leak
The historical way of sealing a new or repaired riveted and peened seam boiler was to throw a few shovel-fulls of horse manure into it and steam it up. The fiber in the manure would find its was into the seams and act as a caulk. Of course the natural fiber would eventually break down but by that time it was replaced by rust and suspended solids in the feedwater.
Sounds like a new name for an old trick.
GWRdriver
Nashville TN
Nashville TN
- Steamer Al
Re: My boiler leak
I sure as heck would not want to be downwind of that one!gwrdriver wrote: ↑Sat Feb 06, 2021 11:29 am The historical way of sealing a new or repaired riveted and peened seam boiler was to throw a few shovel-fulls of horse manure into it and steam it up. The fiber in the manure would find its was into the seams and act as a caulk. Of course the natural fiber would eventually break down but by that time it was replaced by rust and suspended solids in the feedwater.
Re: My boiler leak
That would be a really crappy way to deal with boiler leaks!!!
Re: My boiler leak
I wish I owned a full size steam Locomotive Because I would purchase a horse !
Re: My boiler leak
Horses are a lot more expensive (in the long run).
You only have to feed a steamer when you run it.
