John,
Not my original work - I found a lot of info on the internet. Search for Electrolysis.
-I started with an 0.060 brass sheet.
-I bought some toner transfer paper (used a lot in home brew PC boards).
-I have a laminator and used it to transfer the toner to the brass. I have seen instructions of using an iron to to this, but I was unsuccessful).
-A plastic tank (Tupperware) was filled with very salty water, enough to cover the plate.
-The positive terminal of a power supply is connected to the brass plate. I had a bit of trouble here. It would be better if the connection is not in the water. I might of been able to etch deeper if the connection stayed longer. The wire and mounting hardware etched away in the water.
-The negative is connected to a stainless steel plate. It was just luck that this connection was not in the water.
-I set the power supply at 6V and turned the current up to max (2A). The power supply went into current regulation and the voltage dropped. I have seen examples of people using a 12V battery charger.
-When the power is turned on, you should see bubbles coming from the negative plate and I could see the 'flow' of the water between the two plates after it became dirty.
-I don't know long the process took due to the failure of the positive connection.
-The depth is about 0.010
Here is a more cleaned up picture.
I'm going to try again to see if I can get a deeper etch, but if I fail, these are usable,
Karl
