Pennsy E6 Boiler
Marty_Knox
Re: Pennsy E6 Boiler
Post by Marty_Knox »
And still more
Marty_Knox
Here are some more pictures. The mudring is the only thing left to weld.
Rwilliams
Post by Rwilliams »
Is that some hex stock being used to form the mud ring and give plenty of Vee groove for a suitable weld?
Marty_Knox
No - it is 1/2" x 3/4" hot rolled bar with the weld prep ground off.
Marty_Knox
We finished the welding and installed the tubes today.
Marty_Knox
The boiler was tested today. Glenn pumped it up to 250 PSI at 9:30 AM. At 1:30 PM the pressure had risen to 260 PSI.
We figured that was good enough.
Andypullen
Post by Andypullen »
Beautiful, Marty!
Can't wait to see it in person!
Andy
SteveM
Post by SteveM »
Your work is simply impeccable.
