Brass case 0-15 PSI Gauge wanted
Hello all, anyone know where I can find a mini pressure gauge 1 inch diameter 0-15 brass case gauge?
thank you
Tom
thank you
Tom
Re: Brass case 0-15 PSI Gauge wanted
Get the PM Research gauges and remove the plastic cover and make brass ones.
That's what I did.
I'll see if I can find some pictures.
Karl
That's what I did.
Karl
- Chris Hollands
A good place to buy all sorts of model gauges .
I just bought some gauges from them good pricing , price stays the same for all pressure ranges from the info they sent me .
1"OD without flange = $36US
1"OD with flange =$47US.
1 5/8" OD without flange = $36US
They maybe the company that makes the actual gauges that a lot of suppliers sell ?
Last edited by Chris Hollands on Thu Dec 03, 2020 9:12 pm, edited 4 times in total.
I could only fine a front view with the gauges mounted on a manifold.
Karl
Karl
Thanks guys...but no 1" brass case 0-15 PSI...but I sent an email requesting same.
Turns out I want a 1/2" gauge face.
Just curious, what is the intended purpose for a 0-15 psi?
Mountaineer
Mountaineer
Measuring 7 PSI
Ok, I deserved that answer.
Mountaineer
Mountaineer
- ChuckHackett-844
If you are by chance measuring propane burner pressure: Since low pressure gauges tend to be expensive I place a needle valve between the gauge (25 psi) and the burner and close the needle valve until I have a usable reading (11-12 psi) when the burner is at full usable fire. I really don't care what the pressure is at the burner itself, just a relative reading.
Regards,
Owner, MiniRail Solutions, LLC, RR Signal Systems (http://www.MiniRailSolutions.com)
Mine is an oil eater. I installed a pressure regulator in the atomizer line before a linerier valve. There is a 0-15 PSI gauge in the atomizer feed line, but it is a silver and black 1 1/2" gauge. Butt ugly !
So I want to replace it with a brass cased 1/2" face, 0-15 gauge. The atomizer works best at about 7 PSI. Could use a 3/4" if that is the best I can find
Emfinger:
What pressure regulator and linear valve did you use?
I wish to install the same in the atomizer line on my steamboat boiler.
