Tiny Power M twin
Tiny Power M twin
just a shot in the dark, but does any one have a set of prints for the building/machining of a Tiny power M twin, was gifted a half built M twin but the prints have flown the coop. WOW this thing is big will weigh about 400 LBS when done, and probably will need a bigger boat 23+ foot long and a bigger boiler, thanks in advance Tom alias DUCKMAN .
Re: Tiny Power M twin
Hi
Did you try the current owners of the Tiny Power line. Even though they may not sell the castings they may sell the prints if you inquire.
http://www.tinypower.com/
Bob
Bob
Their store page lists the M twin as castings and blueprints both available:
https://tiny-power.square.site/product/ ... 17?cs=true
-Frank K.
Just trying to save $85.00
- SZuiderveen
Ronnie and Deanna could use the money. They make their entire living building and selling steam boats and steam engines. Send the money!
What do you _need_ the drawings for? It's a vertical engine, with castings- take any set of similar drawings, and they are likely to give most of the answers needed...
(unless the castings are minty fresh, in which case dishing out $85 to the owners is probably the easiest way...)
James
James
purchase the drawings.
technically (and morally)...anyone that copies and sends you the drawings if violating a copyright.
i know...$85 is $85 -> but if you are building a model of that size and don't have $85 for a set of plans...then perhaps the cost of the boat and boiler is going to exceed your available budget..
