Coles Worthington Model Steam Pump
- Chris Hollands
Re: Coles Worthington Model Steam Pump
I have a Keith Watson Worthington duplex pump casting set that has full plans and I started machining the main body .
Not sure what scale it is but its quite large probably to suit his 2.5 scale engines he has done over the years , the body measures about 9.5" long with I think 5/8 bore pistons i'm sure it moves quite a bit of water when required .
Keith was a very good salesman and he convinced me to buy it off him for the challenger as I was going to put it in the tender which will not happen now as I have SS injectors .
If any one is interested I will dig out the plans and the rest of the castings , postage may not be cheap this is a heavy casting set .
it takes very little work to modify a bill van brocklin vertical pump to be a horizontal. i have one under the cab of my 3/4" hudson - looks like a stoker engine but is actually a water pump.
runs fine and a proven design requiring no castings.
For something similar to the Coles Worthington pump look at the Mich-Cal No2 pump drawings in Live Steam Oct 1986 and Dec 1986. This might be what you want. This uses no castings.
- SZuiderveen
Note the end of this clip to see a Bill Harris Worthington pump run. https://youtu.be/KK7GQqPDZUk
- Greg_Lewis
Dave:
What's left of my memory thinks someone in Australia has some nice castings for a similar pump. I don't remember where but you might try contacting these:
sales@ejwinter.com.au
sales@dncsystems.dynalias.com
warrick_sandberg@hotmail.com
I know for certain that there was an article about it in Australian Model Engineering magazine. You can contact them here: https://www.ameng.com.au/contact_the_au ... gazine.htm
- Chris Hollands
The castings I have are Australian ones from Keith Watson ( Wato Loco Works ).
Also there is a similar duplex pump from the UK - Southworth Engines in Chesterfield UK and a build series in UK model engineer magazine -
June 93 and Jan 94
June 93 and Jan 94
There are articles in the Australian Model Engineering back issues 113, 114, 115, and 117 but they used castings to build the pump
Regards
Garry
Regards
Garry
