Re: Future considerations from EE
Posted: Mon Mar 01, 2021 11:21 am
ALCOSTEAM,
I plan to produce them in 1" and 1.6". At the moment all the molds are done for the 1" version.
Not sure if I ever posted the final list of future products here on Chaski, so just in case here it is.
- "Consolidated" Safety Valves (1.6" and 2.5" scale)
- "Coale" Safety Valves (1.6" scale)
- **Nathan Top Feed Checks (1.6" scale - 2 styles)
- Nathan "R" Simplex Lifting Injector (1" and 1.6" scale)
- Nathan Reversible Check Valves (1" scale)
- **Bull's Eye No.9 3-feed Working Hydrostatic Lubricator (2.5" scale)
- Hancock Vertical Check Valve (1.6" scale)
- Nathan Reversible Check Valve (1.6" scale)
- Westinghouse Cross Compound Castings (1.6", 1" and 3/4" scales)
** indicates pre-order only, extras will not be made
This is what you can expect to see from EE over the next 2-3 years. No doubt other products will slip in here and there.
My first priorities after the Nathan 4000's are done will be 1.6" and 2.5" scale safeties, followed by the Westinghouse XCompound castings in all 3 scales. The Simplex injectors will be produced before the end of this year in both scales as well.
Anthony
Anthony
