Future considerations from EE
Re: Future considerations from EE
I would be interested in nathan or hancock boiler check valves....are you considering adding those along with the top.mounted check valve ?
That one will be close enough for what I'm building. I'm just glad someone is willing to offer it!the more modern version of that Nathan double check valve, used by N&W was slightly different.
How about some nice looking, steam.operated cylinder cocks, and a 3 way valve to operate them.??....that would be a very welcome, nice addition to.your line !!!!!!
- AnthonyDuarte
Again, there are some products in the queue that are obviously needed and are for sure going to be produced. But I want to hold off on announcing those until they’re further developed.
These are items that I would like to make but it’s not as obvious to me that enough people want them to justify it. The 2.5” scale lubricator is proving to be a feasible item, and possibly the top mount check valve.
As for sources, steamtown is an invaluable resource. There are many historical societies, museums and libraries that have sizable drawing collections. Just comes down to figuring out who might have what.
Anthony
Anthony
Why does a two cylinder loco have a 3 or 4 feed hydrostatic lubricator?
Mountaineer.
Mountaineer.
They fed oil to cylinders, and air compressors
Superheated locomotives had oil fed to both the valves and cylinders, so they would use a 5 feed lubricator.
Shay locomotives in the woods had four feed Bulls Eye lubricators! Three for cylinders and one for the steam engine brakes on those locomotives without air brakes. So many variations.
Keith
Keith
Hi Anthony,
I’ll take a minimum of 2 Sellers injectors. Maybe 4.
I might be interested in the lubricator as well.
Thanks!
Andy Pullen
Thanks!
Andy Pullen
The 1" starter valve would be nice. Keeping the controls different in the cab can help reduce bumping the wrong ones.
-ken cameron
mailto: kcameron@twcny.rr.com
the market is lacking boiler checks, there are some basic version,
the top mounted boiler twin checks are cool, but i am not sure what vintage something like that would be seen on.
none the less, i need to come up with a solution for my early/light pacific i am building in 1.5/1.6 scale.
about a year out from needing something.
I have many of your products now that are going on this locomotive. boiler checks will be right at home
Incase anyone is wondering, this is the Allen ten wheeler that i converted over to the a light pacific.
I second that !!!....a good variety of boiler check valves is a big gap in.the live steam.window right now.....those would be a most welcome addition.!!!
