inverted-rocker lateral-motion device
Hello all, Dose anyone know of a print or information on this , I have seen this in a few books and pictures,I would like to use it on my engine if it can be made that small, the engine is in 3/4" scale 4-8-4 northern,any help would be great.
stay on the shine side of the rail
Re: inverted-rocker lateral-motion device
I recall seeing something about these in the ICS course material on steam locomotives. I used that (conceptual) information to design one for a 2.5” scale locomotive. You’re probably on your own for design details unless you can get plans for a specific prototype locomotive. Another source might be a later edition of the Locomotive Cyclopedia, such as 1941.
Dan Watson
Chattanooga, TN
Chattanooga, TN
Good luck with that. Yes you can make them but they are always falling out on the ground. After a few years of screwing around with them in mr 3/4 hudson...I took the roalckers out and put in rollers. Not very true to scale but a lot more practical.
The langworthy hudson prints have some very useful dimensions as a place to start
I wasn't sure what you were asking for until Bill commented, pretty much the same thing he told me about six years ago. I used inverted rockers on the leading/trailing trucks of the GG-1 I was building, they sort of worked, but were always flopping around. I put lateral coil springs on them to help re-center them when the engine came out of a turn, it helped but it needed a long straight run to get everything back in line. Check out the PA State archives for the GG-1 truck drawings; all my drawings went with the engine when I sold it.
John
John
Here at Chaski back in 2012 under 'Riding Scale Railroading' titled 'GG-1 in 1-12/" ' are plans for the GG-1 trucks that I previously referenced.
John
John
Attached is a photo of how i did it.
The bronze 'rollers' replace the rockers. they are sitting on a 10-32 SHCS with a steel sleeve up the center to allow the bolt to go tight without clamping down on the roller.
The rollers riding in an inverted V pocket so that they tend to be self-centering
I used the same V pocket idea that the rockers would use.
only I had to make them a bit wider to accommodate the roller (experimented a bit).
