Bunting P43-4
Bunting P43-4
I came across a reference in building the RRSC mikado to Bunting P43-4. I see "Buning" is both a company and type of bearing material. But I cannot come up with P43-4. Is this an old reference and what would be a good cross. I assume a porous bronze would be good. But then you know what assume means.
Thanks for the help.
Dale Grice
Dale Grice
Projects:
1.6 CB&Q O1a Mikado
1.6 CB&Q NE7 Waycar
RR Supply 90 ton Logging Mikado
1.6 CB&Q O1a Mikado
1.6 CB&Q NE7 Waycar
Re: Bunting P43-4
What was it used for?
Re: Bunting P43-4
That is what is commonly known as oilite bronze. It is formed from powder under high pressure to produce oilite bronze bushings
Re: Bunting P43-4
It is used for a bushing in the valve gear link support. Drawing (in theory) here:
https://drive.google.com/file/d/1zI8Qiw ... sp=sharing
Projects:
1.6 CB&Q O1a Mikado
1.6 CB&Q NE7 Waycar
1.6 CB&Q O1a Mikado
1.6 CB&Q NE7 Waycar
Re: Bunting P43-4
The SAE specification for sintered bronze Oil-impregnated bearings is SAE 841, aka “Oilite. Cast bronze is SAE 660, aka C93200 alloy.
Dan Watson
Chattanooga, TN
Chattanooga, TN
Re: Bunting P43-4
Do not use it in any area subject to repeated impact loading
Re: Bunting P43-4
I wouldn't use it on a locomotive, use a good grade bronze with a oil hole.
I do use "oil-lite" bushings on my non riding cars and they work fine.
Re: Bunting P43-4
I use Oilite bushings in all my Allen Ten Wheeler rod brasses.
They show no wear after 600+ miles of steaming.
I did drill tiny oil holes through the tops to facilitate lubrication from the small reservoirs above.
Maybe that makes a difference.
Re: Bunting P43-4
Thanks all for the replies.
Dale
Dale
Projects:
1.6 CB&Q O1a Mikado
1.6 CB&Q NE7 Waycar
1.6 CB&Q O1a Mikado
1.6 CB&Q NE7 Waycar
