Bagley burner too hot.
VGC
Re: Bagley burner too hot.
Post by VGC »
Asteamhead wrote: Fri Feb 21, 2020 12:37 pm Maybe this helps?
http://ibls.org/mediawiki/index.php?tit ... Oil_Burner
Asteamhead
See this comment of an also very good model engineer:
https://www.chaski.org/homemachinist/vi ... 12#p387773
Perhaps it is not a good idea to regard this solution as just one of many ones ;-)
Vance Nickerson
Post by Vance Nickerson »
If you want to sell the Bagley I would be interested.
Vance Nickerson
nickersonvance@gmail.com
JHannah
Post by JHannah »
Vance Nickerson wrote: Fri Jul 24, 2020 3:25 am If you want to sell the Bagley I would be interested.
Vance Nickerson
I hope you aren't thinking about using that in the c-16...
Vance Nickerson
Like to have a spare laying around never know what locomotive is going to come in my shop for rebuilding. C-16 issue is finding a good coal supplier. Only need a few bags to test it out and will probably get some off the discover live steam site. It did cross my mind and if i were going to keep it the Bagley would be installed but for others it's probably better off coal fired.
Santafescotty60
Post by Santafescotty60 »
Hello, I would like to know the "to hot burner symptoms", are you able to pull a yellow flame with some blue specks in it , are the safeties popping on set their pressure ? and what is that pressure?
Cheers Scotty
Emfinger
Post by Emfinger »
Hi Scotty, if you read the first page you'll see that thanks to Steve the problem is solved. I built a needle type valve with a much smaller seat. Now for the first time ever I am in control of the flame in my fire box. Adjustable from "pilot light" to inferno.
Thank you for your interest in my problem.
