Re-light an oil burner
Re: Re-light an oil burner
The link above to model engine plans, they sell a kit for a buzz coil, works great on my Oil fired Mikado. Works on 6 or 12 volts, I used a champion heater igniter has about a 2" reach so it is closer to the fuel spray. Works great.
- Greg_Lewis
That looks like the answer. They have some cool stuff that would result in a reliable setup.southwestern737 wrote: ↑Mon Dec 16, 2019 8:28 am The link above to model engine plans, they sell a kit for a buzz coil, works great on my Oil fired Mikado. Works on 6 or 12 volts, I used a champion heater igniter has about a 2" reach so it is closer to the fuel spray. Works great.
But the cheap arc lighters look like they'd be fun to play with. You could take one apart, put the spark gap in the firebox and hide the rest under the tender deck. And you'd only be into it for about ten bucks.
- Dave_Johnson
Tom,
Do you have electric lights for the loco? I use a lawnmower battery that I carry in the boxcar behind the loco.
you can stick a coil of nichrome wire inside the firebox.
That sounds like an excellent method to keep a hot ignition source in the flame path.Bill Shields wrote: ↑Mon Dec 16, 2019 9:08 pm you can stick a coil of nichrome wire inside the firebox.
I will try that too, if needed.
BBQ lighters will only work with propane, you need a lot more heat and flame to ignite diesel.
I recommend a handheld MAP gas torch to get it going. A propane torch also works.
One bottle will last ages.
-M
-M
Guys, I built a spark generator that runs on 4 "D" cells and is smaller than a cigar box. The spark is about 60 KV and will arc 3/4". The batteries seem to last forever. Works for me and for $235 it could work for you too.
Tom Emfinger
Tom Emfinger
- makinsmoke
Mike,
This isn’t coal we are talking about. You can light diesel with a match if the air/fuel ratio is correct.
I’ve used the little hand held lighters with the long noses. I think everyone migrated to the butane and MAP torches because they have a longer reach, saving your arm hair in a late reignite!
Take care,
Brian
Take care,
Brian
A model T coil and a spark plug will light properly atomized oil
have you ever lit a cold burner with a match?makinsmoke wrote: ↑Mon Jul 20, 2020 10:59 am Mike,
Take care,
Brian
I have, turn on the oil, with the match in the door, and slowly turn the atomize valve.
Thanks guys, but nothing is faster or easier than one push of the button on my magic box.
