Vacuum diaphragm
Vacuum diaphragm
Does anyone know where I can buy a vacuum diaphragm for vacuum brakes?
Re: Vacuum diaphragm
Mountain Car Company uses them in the brake kits they sell, so you might try them. These are basically just little vacuum devices like are used for vacuum advance on automobile distributors. If know what you are looking for, the friendly parts counter folks at the local NAPA or O'Reilly's might help you find what you need.
I hope that helps,
Bill C.
I hope that helps,
Bill C.
Joseph Nelson has a part number in his book (So you want to build a live steam locomotive) for a Delco Remy part number F-1302 which is for a 3 inch diameter vacuum advance for a Ford Distributer. It is in chapter 14 on a simple train brake system.
Talking with a fellow modeler up north, I understand this number may have changed but you may still be able to cross reference at an automotive parts store.
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
Current Projects:
- Trainman4602
Hi All
I have around 20 of the vacuum chambers that Charlie mentioned. I would like to sell them here is a picture .
They are the exact part pictures described in Joe's book. There were to be used on 6 wheeled passenger cars but I developed the air brake setup and never used them. They are 3 inches in diameter. PM me if interested.
I use the heat/air conditioner damper diaphragms from a junk yard. They are typically larger than distributor advances.
Fred V
Pensacola, Fl.
Pensacola, Fl.
Go to Reilly Auto parts and buy online - or Ebay.
- Dan Willey
I recently rebuilt a couple Mountain Car Company trucks that have brakes. I researched and it seems that MCC used a "choke pull-off" from a 1980's Ford. The vacuum pull-off is modified a bit... mounting bracket cut/ground off, and adjusting screw replaced with a screw-eye. I found them all over eBay and bought one as a spare.
I have attached a couple photos of the rebuilt and painted MCC truck and brake rigging.
Here is an example on eBay ($14.95 free shipping). The prices are all over the place so search carefully.
http://www.ebay.com/itm/Standard-Motor- ... fc&vxp=mtr
Dan
Dan
1/8 scale: Mercer Locomotive K4, Saturated Steam E6
Full scale: Woodings CBL speeder/motorcar NARCOA
Hi Dan, thanks, you gave me the information I needed.
- Greg_Lewis
Some years ago the late, great, Charlie Dockstader sent me drawings for making your own out of PVC pipe and old inner tube rubber. If anyone would like a copy of the drawings, send me a P.M. and I'll email them to you.
I use the Mountain Car Co. vacuum brakes shown above, and have learned one issue that should be attended to before putting them in service:
The plastic body material is relatively soft and the threads for the screw eye-bolt in the vacuum cylinder will wear and begin leaking air, decreasing the available vacuum. I have "R&Rd" them by sealing the eye bolts in place with silicon rubber sealant. Problem solved.
Thanks for the drawings, Greg.Greg_Lewis wrote:Some years ago the late, great, Charlie Dockstader sent me drawings for making your own out of PVC pipe and old inner tube rubber. If anyone would like a copy of the drawings, send me a P.M. and I'll email them to you.
Just wanted to mention that there are not only the brake vacuum cylinder but a brake valve and steam ejector plans too. A little difficult to read but the info is there. One doesn't have to use pvc, the brake cylinders could be made from brass using the same dimensions.
Good stuff if you like to build your own equipment.
-Larry
I enjoyed seeing them too. I would like to comment on the ejector. If the exhaust side were made longer a lock nut could be added to aid adjustment.
Fred V
Pensacola, Fl.
Pensacola, Fl.
