Small railroad bridge
Forum rules
We are building a small railroad bridge for a 2 ft. gauge track. Total length is 10 ft. We have concrete supports on both ends and middle. Our total load is less than 1000 lbs. Should we use "H" steel, 3" square tubing, or 3" channel iron? We have galvanized 3" angle that we could attach treated 4x4's to for attaching 4x6 crossties.
Re: Small railroad bridge
H or I beam
You have to consider 1000# in the center of the bridge and distributed weight of track and ties plus riding cars and passengers...and assume that at some time the future the center support may settle a bit
Plus the possibility of a derail in the center of the bridge with maybe 6 men to get it back on the track.
All of a sudden your 1000# load looks very light.
And what happens when someone brings a 3000# loco to run?...ask him to weigh it..giggle
You can never use too much steel
Find some used structural beams
Personally I’d be inclined to build it with 4x6 wood stringers, with one bent in the middle. Traditional RR design. Easy to build, using 10’ timber’s. Carrying capacity up around 4/5 tons+. Plus you have an authentic trestle when your finished.
Glenn's trestle is really nice, I'd agree to use your 4x6's for stringers, the 4x4's for cross ties, and incorporate the 3x3 angle for brackets and braces (you don't say how much you have). For a 10' span I'd probably want 2 bents, but I'm all for overkill so it's up to you.
FYI, treated lumber contains copper and other chemicals dissolved in an acidic compound. Especially in wet environments, the addition of galvanized steel parts essentially creates a battery, which will quickly corrode and consume the galvanized zinc (anode) brackets and fasteners. I highly recommend either sealing the treated lumber (including the holes you've drilled) with an outdoor water proofer, or at least bed the fasteners in wax, sealant, or caulking. You can use tarpaper soaked in water proofer as an isolator between any angle brackets and the lumber. I've taken apart deck structures that are less than 5 years old and had the heads pop off the galvanized fasteners used (that looked good from the outside) because the rest was literally corroded away.
FYI, this is from our engineer we work with where I work. I had proposed just using two steel beams with 4x4 ties carraige bolted to the top chord. Unofficially, of course, you know how it is.
"If I were building a 5 to 6 foot wide bridge with two steel stringers spanning 8 feet, I would use any of the following for the steel stringers: W4x13, W5x16, W6x12 or W6x15. I like these better than a W12 because the shorter shapes are less likely to roll or buckle. I used 100psf live load or 5000# in the center of the span for my check."
If you wanted to go free span, two W6x15's should do it with proper beam seats. Add a couple steel cross-braces and your loading goes up exponentially. I have access to lots of scrap so I will probably be going this route when I start laying my track.
+1 for what Ryan said. Not sure what to do about treated wood these days. Use rebar for spikes maybe. In lieu of galvanized spikes.
Forgot to mention, my bents are on 4’ centers, and the ends bed a couple of feet behind the revetments- for stability.
The uprights are 3x5” recycled, old growth, clear grain fir - seasoned in salt water at a cannery for 50’ or 75 years. ( I have a secret stash I use for special projects )So fully saturated with salt and fish oil that bugs and dry rot don’t stand a chance. They don’t even weather when stored outside in the rain. Nothing affects them! I treated them with hardware store cuprinol just to darken the wood a bit.
The problem is the steel in general. You've got the copper, the acid, and the steel/zinc which end up being the anode (eaten) metals. Essentially add moisture and you have a battery, electrolysis will consume the lessor metals.
Coating or bedding galvanized fasteners (try to get hot dipped stuff, not zinc plated) in something will buy you more time. I was examining an older wooden bridge and it looked like they had used hot dip galvanized threaded rods bedded in tar where they passed through the piles and creosoted lumber. Or, you can spring for stainless. FWIW, deals can be found on stainless threaded rod if you can get it wholesale so it may not be that much more than hot dip galvanized.
