CAD CAM software
Related to all sorts of CAD and CAM tools. Users should post questions, comments, and recommendations with respect to their favorite CAD and CAM tools.
Moderators: Harold_V, GlennW
Harry Shonteff
CAD CAM software
Post by Harry Shonteff » Thu Jun 18, 2020 5:09 pm
I have been using Rhino cad and cam for a few years. However the Windows 10 upgrade has ended my cam use and MecSoft will not offer support because it is a few years old. I was told the upgrade messed up the dongle. Any way I want to up grade my cam software. I make custom sewing machines so a lot of small precision parts. The last upgrade was an extremely bad experience. I bought a new computer. Then the Cad Cam package would not work so I upgraded them both. Then the CNC Jr still would not work . I had to but all new motors and electronics. So this computer upgrade was $13K.
Now I am in need of a good new CAM package to make my tools paths. Any advice would be great. This is for a home shop not General Motors
Harry
San Francisco
www.a1sew.com
Re: CAD CAM software
Post by Harold_V » Thu Jun 18, 2020 6:15 pm
Welcome aboard, Harry.
We have some outstandingly brilliant computer people on this board, so I suspect you will receive some excellent guidance.
pollys1dad
Post by pollys1dad » Fri Jun 19, 2020 6:54 am
Harry
San Francisco
www.a1sew.com
Hi Harry, there is a forum called Bleeping Computer, https://www.bleepingcomputer.com/forums/
Lot of folks with a lot of know how, could try there. Good luck :)
Gary Armitstead
Post by Gary Armitstead » Mon Jun 22, 2020 9:01 pm
Why not have a "dual-boot" system and partition the drive? OR you could also use freeware called VM Ware, that will allow you to run your computer as two separate machines. The Virtual Machine software will still recognize the dongle and Rhino will run just like it always did. I use MasterCam V9 (2002 circa) with a dongle that will only run on XP Pro and will not run at all on Win 10. Now I run MasterCam on my Win 10 computer, but MasterCam "thinks" it's running on a full blown XP Pro computer. You might need a good computer geek to do this for you. Definitely not for a novice :).
Gary Armitstead
Burbank, CA
Member LALS since 1980
Member Goleta Valley Railroad Club 1980-1993
Post by BadDog » Tue Jun 23, 2020 1:08 am
I seem to recall that once upon a time, MS offered a free XP Pro VM for use on their virtualization platform. I believe that was for "Virtual PC" IIRC?. That may or may not still be available, but if so, would be preconfigured and easily setup. I would expect the only thing necessary after install and initial setup would be to bind the USB dongle to the VPC instance. If you have a machine with decent speed and sufficient memory, virtual machines are a great option. But I would recommend physical hardware with enough real RAM to fully support both the VM and host OS. Technically not required, but if you rely on sharing, things slow down in what seems a near exponential degradation. And a fast SSD SATA (or equiv) drive for persistent memory also helps a lot, as does a real multi-core CPU. But all these things are relatively common in recent generation desktop machines, and even many laptops.
On VM Ware, I'm not sure what their free licensing looks like, but IIRC, the player is free, but you can't setup your own VMs. You have to find one (may also be free downloads?) that will work for you, and just run it. But that detail may be out of date.
LIALLEGHENY
Post by LIALLEGHENY » Wed Jun 24, 2020 12:21 am
It's very simple, have one computer running XP for your Rhino software, and your other computer running Win 10 for everything else. I have Mastercam V8.1 (2000 vintage) on an older machine running XP. You can get the older machines for next to nothing, or in my case it came from someones trash. It is also good to have a dedicated computer for your CAD that is not online....then you don't have to worry about being hacked, getting a virus, etc
Nyle
Post by Bill Shields » Wed Jul 08, 2020 3:43 pm
Autodesk Fusion will drive a basic 3A mill or 2A lathe with little trouble and low $$ and runs on Win 10
dorin
Post by dorin » Tue Jul 28, 2020 6:41 am
I really like Estlcam, for a low-cost cam tool. https://estlcam.de/
However Like Russ mentions, a virtual machine might not be a bad idea.
You could try spending $25.00 or so on Windows XP from Ebay and then install virtual box on your new pc. (which is free)
(Or do you have your old Windows XP install CD or recovery CD, that might work too and be free!)
VirtualBox can be found here: https://www.virtualbox.org/
You basically run XP inside a window on your new windows 10 machine.
This is not too hard to do.
-Mike
www.chaski.com
Adirondack
Post by Adirondack » Tue Jul 28, 2020 11:03 am
-Mike
Mike, can it be used for turning? I went to their website and it looks to be mill-centric. How does it compare in ease of use to the other major players?
Chris
Adirondack Car & Foundry
Check out our projects: https://www.facebook.com/ADKrail/
Visit our ALL-NEW online store: https://adirondackcarfoundry.square.site/
A little locomotive with 4 wheels on the track is a lot more fun
than a 1/2 finished one with 16 wheels on the bench!
dorin
Post by dorin » Tue Jul 28, 2020 1:25 pm
Chris,
I bet it can't be used for turning...I see a comment on the web wishing for "Estlcam turn."
I am not experience with other tools...but for me, for the milling, it is super intuitive.
(It could be that I am just nuts too!)
The nice thing is that it is free to try. It is actually free forever, but if you don't buy a license
each job takes longer and longer..
-Mike
www.chaski.com
Adirondack
Post by Adirondack » Sat Aug 01, 2020 4:14 pm
Chris,
-Mike
Bummer. I have no love for Fusion and its CAM module for my lathe.
C.
