Victorian R-CLASS 4-6-4
VK2DJ
Re: Victorian R-CLASS 4-6-4
Post by VK2DJ »
Hi All more progress pix of the tender build getting there slowly , still cant see the light at the end of the tunnel
Vr160
Post by Vr160 »
VK2DJ wrote:Hi Luke the R as far as I know they never used solid wheels at all they were all 10 spoke
Gary
Thanks Gary for the info. I had it pointed out from an other member of this forum that solid wheels were used on the SG conversion R. The tender is coming along nicely. Keep up the great work.
VK2DJ
Post by VK2DJ »
Hi All not much to show for a lot fiddley work screwing together then unscrewing to check fit nearly ready to solder together
temp screwed together
mock up oil tank
mock up oil tank
VK2DJ
Post by VK2DJ »
G'day People further update on the tender build main tank screwed together, riveting complete starting on some detail parts, not going to solder it together yet just in case I have forgotten something.
Gary
SilverSanJuan
Post by SilverSanJuan »
Really beautiful work there, Gary.
Todd
VK2DJ
Post by VK2DJ »
G'day All finally received the scale brake blocks for the tender, the 3D modelling was done by Philip Monsbourgh in the Netherlands ,the casting was done by Michael Jack in New Zealand, very pleased with the results they add realism to bogies
Blocks as received
Blocks as received
VK2DJ
Post by VK2DJ »
Progress update on the Hudson's tender under frame detail a lot of work not a lot to show
Buffer keying method to stop buffers rotating
Rear spring loaded coupling
Engine coupling end
Engine coupling end
Rear buffers fitted to beam
Asteamhead
Post by Asteamhead »
Hello Garry,
when I scrolled all your impressive photos, there was the information regarding working preasure of your vessel (90 psi).
My type of oil burner should get a nozel of 0.6 mm to 0.7 mm diameter (steam).
A nozel of 1.6 mm diameter should be used for the fuel then. (The drawing is showing these dimensions, too).
These dimensions will atomize about 4 liters of diesel per h @ 90 psi with an adequate amount of steam.
The steam nozel should be tapered slightly (Laval). The adjustable outer nozel must get a precise fit not to suck air instead of fuel.
The adjust may be done either by a lever (as shown) or a gear (for more precision). The angle to be turned from 'shut' to 'full' will be less than 90° @ thread of 1 mm / turn.
Asteamhead
Burner for a French (US) Mikado 5&quot;<br />Very similar to that of my class 44
Burner for a French (US) Mikado 5"
VO4454
Post by VO4454 »
Gary, Your tender is a work of art . As someone who appreciates the details, your attention to them is outstanding.
Vic
For Duty and Humanity
VK2DJ
Post by VK2DJ »
Thanks Vic for your comments its the detail that makes the difference a lot of work & not much to show
Also thanks Wulf for the info on the oil burner
Gary
VK2DJ
Post by VK2DJ »
Progress on the build has been interrupted by a 5 week holiday to the UK to visit the Harrogate Model Engineering Exhibition then some home renovations,
The tender under frame is finished started the detail on the tank then realised I still have approx.6 months to finish so I decided to have a change & finish the boiler
Progress so far on the tank detail
Foundation ring soldered in &amp; finished soldering the stays inner fire box back head installed
Foundation ring soldered in & finished soldering the stays inner fire box back head installed
Boiler ready to solder in the front tube plate
Very nice!
Continued success.
